Hi all,
I want to share with you the first results obtained with my Bixler-UAV. I had never flown a RC plane before but must say that this little hobby quite gets into your skin once you get familiar with all the basics. So I started with an Bixler ARF kit and made must adaptations according to this guy:
Make sure to read all about CG before your first test-flight, or you’ll be climbing trees to get back your precious toy. Needless to say that the learning curve was steep..
Today was a calm day (7km/u wind), perfect to make the first flights with a camera.This is the setup:
Airframe: Bixler - Still my first one. Unbelievable tough and when you brake something, there is always the CA glue to the rescue.  I moved the ESC outside so it cools down easier and you can connect the battery without moving the mounting platform with all the electronics. I also cut out a hole  below the nose of the plane for the camera to fit. Foam along all sides of the camera should reduce the vibrations
Autopilot: APM1 with GPS, airspeed sensor, magnetometer and 2.4GHZ Xbee. Except the X-bee, everything is mounted on the Bixler electronc chassis. Works like a charm, just as described  by all the great people here at the site. I used the bixler.param file posted by Chris and played around with some of the PID settings. Now with the camera integrated I have to do some more twitching with the extra weight.
Camera: Canon IXUS 220HS with CHDK interval meter. Just like these guys from conservationdrones.org/.  Fits perfect in the nose
Morning flight
Camera setup: Focal length: infinity; ISO:auto; Shutter time: 1/500
Average Altitude: 100m (still to verify)
Average Ground Speed: 12m/s (still to verify)
Number of images taken: 260 (did the track twice). I had many blurred images and had to remove 140 images before stitching. Shutter time was set to fast.
Evening flight:
Camera setup: Focal length: infinity; ISO:auto; Shutter time: 1/1000
Average Height: 100m (to verify!)
Average Ground Speed: 10m/s (to verify!)
Number of images taken:194. I had only 6 blurred images, but overall scene was too dark. Next time I will fly with better illumination conditions.
The stitching was done with Microsoft ICE, I will also be looking into software which include the GPS/IMU information into a real map.  Comments, suggestions,.. always welcome!
cheers
Dries
Nice job Dries, your map looks great!
Great map! How long did it take you to stitch it in ICE?
Well done, great result. I ´m doing mapping to buth with the Zephyr II
Well done! Not much to add. maybe
have a look at Apero/MicMac.
