Hello, my name is Lee and fairly new to coding. I'm trying to adjust the "Sparkfun 9DOF Razor IMU AHRS" to read the following:
Linear: Acceleration, Velocity and Position in the X,Y,Z axis.
Angular: Pitch, Roll, and Yaw angles and rates.
My end goal is to use this code for my research, which is to make an unstable, 3-engine UAV hover. Unfortunately, my angle readings are... frustrating.
I start the accelerometer on the table, see how the readings drift. (About 0.1 degrees per second)
Then I tilt the 9DOF stick about 90 degrees. (Only reading about 70 degrees instead of 90)
And then I returned the 9DOF stick to level. (The readings begin oscilliating between pos/neg 70 degrees, very slowly.)
My code so far is below. ... Please help me.
