ahrs_wind_max setting with Airspeed Sensor
Hello All,
I was wondering how you guys are using the ahrs_wind_max setting with the airspeed sensor from 3DR? I've noticed that on most flight logs, this setting is set to zero, however, I'm curious if anyone has an opinion or a setting that contains a value. Would a wind max like 5 m/s be beneficial if the sensor were to fail mid mission?
thanks,
Nate
  • Hi,
    I am also looking for the parameter. It is set to 0.
    The place where I live have wind gusts of 24 kmph.
    Will increasing this parameter actually take more from the baro?
    Regards..
