I recently bought an air speed install sensor and was about to hook it up with my APM on my bixler.
Everything is pretty much diagrammed and pictures are provided, except theres no pic for the final setup.
https://code.google.com/p/ardupilot-mega/wiki/Airspeed
The sensor has two tits or ports to connect the silicon tubing so does the pitot tubing. However does it matter which is joined up with which ? The walk thru does not provide a final picture(it should just so people can confirm their setup) nor does it comment on this.
Can someone confirm does it matter ? i just want a confirmation so i thats one less mistake, in my setup.
The tube coming straight out the back should go into the top port and the tube exiting at an angle should connect to the bottom port on the airspeed sensor.
