Hello, does anyone can explain way the acc level is measured everytime i start the APM ?
Way the APM not work like a multirotor that the adjusted horizontal level are stored in EEPROM ?
today i started my apm in an not horizontal surface then the aircraft every roll to right.
if a correct level are in the EEPROM this problem never occour.
sorry for my poor english.
Because the accelerometers are not temperature compensated. Every time you start up they may be different.
What multirotor are you referring to? The why, see previous answer.
Then don't do that.
This is an open source, DIY project. Alter the source to suit your needs.
Well, i fly mikrokopter for years and never have problem with temperature in acceleromter.
I have my own multirotor flight controller and only do the ACC level calibrate when i installed the board on the frame.
The multiwii use the e2prom stored acc level in multirotor but in fixed wing it use acc level when system start.
I never understand way fixed wing use this kind of acc level.
BTW, i think ACC are not affected by temperature .
I never see anything about this in datasheet.
I modify my APM to work with E2PROM stored ACC level.
