Altitude drops when fast forward, then jumps up when stop
probably already old thread but i'm new to APM
and I had this same issue with NAZA v1:
when i fly in alt-hold,  and i push the pitch stick forward to almos the max  the quad fly fast but it loses altitude like 1-2 meters, maybe more, but when i stop it, the quad gain altitude very fast, like it was taking a breath :)
and then it stabilizes
my point is, ti seems impossible to do aerial photography following  a car for instance, if the altitude drops right?
  • On my Naza I just increased the vertical gains until it stopped doing that as much. Switching to a 4S battery helped a lot too. I'm not as familiar with adjusting the same in APM though.
  • if you use a canopy, (or anyway, based on the build) - leaning into "wind" generates a lower pressure "behind"  - where APM is  - this will make the barometric altimeter sense a pressure drop(= indicated altitude increases, and it will try to correct by reducing thrust.)   - then you stop, the actual altitude is sensed, and it goes up.
    If you want to fly precisely fast or in strong wind, you need to have a frame/chassis that does not influence pressure too much.
    • interesting... so you suggest to use a canopy? where is the baro sensor on the APM? i do have the APM plastic case anyway... shoudln't be enough?
      sorry... or do you mean it's the case/canopy that create this problem and the APM should let be "breathe" outside the case?
      • depending on the case, connectors used/open  - you can imagine that under certain flight angle, air will "blow" into bigger connector openings, giving a pressure increase, or the connectors can be on the rear of the airflow, giving a pressure drop inside the case.
        It all depends on the way case,canopy, and frame is designed.
        another simple solution is to put tape over any open connector spaces, leaving only a 1mm gap on front and back.  - this will minimize the pressure change and air that get "packed" into or sucked out of the case.
        of course, reducing autopilots altitude compensation can help, but it's just a workaround, it does this because it
        's influenced, otherwise it would do so all the time.
        Finally - vibrations can influence Z position too, (make it think it falls/climbs)  - check logs for that, but I don't have reason to say that's the problem.
DIY Robocars via Twitter
https://t.co/goTOm2tmK7
14 hours ago
https://t.co/gAmme4l1pn
14 hours ago
https://t.co/sI9IXSyTA6
14 hours ago
RT @SmallpixelCar: Test my algorithm on real car https://t.co/idWRxcrmuK
Tuesday
RT @breadcentric: Evo is coming to town. If you have an #AWS #DeepRacer, you can purchase an extension pack! https://t.co/w60JwI98Hp #Machi…
Monday
https://t.co/bzpbxytpsv
Monday
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Jul 7
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Jul 6
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Jul 5
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Jul 4
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
