Altitude issues in Loiter, high Nav pitch demand, abrupt crash in Fly by wire
I had a routine flight for an hour or so with my pixhawk in arduplane 3.5.2. The plane flew well for about fifty minutes or so in auto. After that, I switched to loiter a couple of times. Each time, the altitude dropped immediately on switching to loiter. I then decided to land and switched to FBWA. I started to approach for landing, when suddenly, after a turn, the plane plummetted nose down and crashed.
I was using a RFD900 for telemetry.
Some observations I've made -
  • The mission planner showed an altitude of 17m at the time of the crash.
  • The Nav pitch was always high, about 40 degrees during the auto flight
I tried to attach the logs, but I couldn't because of the size limit, so I have put it in a drive link
https://drive.google.com/file/d/0BzvtRMZaahWwWHk1UW0tNE5Xdlk/view?u...
Any help would be much appreciated. Thanks
I would like to see the answers to this also.
Amm, do you make the write Compass altitude setting? I mean if you now in the ground, does the telemetry says u r at 0 altitude ?
Also do you set the Loiter settings ? altitude and if there another ?
Hope u fixed it though xD
Please post if it is fixed.
