Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
yes, I do have long/alt info in the very first screen. also, I will try to flash my taranis with a new fw, as I am still using whatever it came with.
yes, indeed I appreciate the armed/disarmed status and no pressure on the flight mode status, just a friendly reminder that it would be a great addition!
Thanks Rolf,
I have here a Problem:
mavlink_msg_statustext_decode(&msg,&statustext);
MavLink_FrSkySPort_V1_33:328: error: 'statustext' was not declared in this scope
Peter
Sorry,
you must declare it in the beginning of the file, like this
mavlink_statustext_t statustext;
Any ideas' on how to show the  status and ARMED/DISARMED?
The Auto Pilot Mode is a number from 0 - 13
and the Armed/Disarmed is 1 or 0.
TNX - compiled now.
Now I have:
// MAVLINK_MSG_ID_STATUSTEXT
uint8_t     ap_severity = 0 ;
                              case MAVLINK_MSG_ID_STATUSTEXT: {
                                  ap_severity = (statustext.severity);
          if (ap_severity == 0x01){
            digitalWrite( PORTNR_CH4 , HIGH);
Compiles but does not work.
have you set pinMode(PORTNR_CH4,OUTPUT);
The code works on my test....
Yes, i have.
debugSerial.println(ap_severity);
debugSerial.println(statustext.text)
show also nothing.
Peter
Can you attach your code as a .zip file  so i can look at it?
OK, done.
You have put hte brake in the switch command at the wrong place. ;-)
Try this ...
Thank you for the time you give to me, Rolf.
It's funny, the file from you also will not work.
I have set in the MP FS_BATT_VOLTAGE on 14 volts.
With a power supply I rule the supply voltage from 16 volts down to 13 volts.
But the LED remains off.
Peter
