Amperage/Voltage dependant triggers?
Is there a way to trigger/jump to a new navigation command based on a low MAH level or voltage drop?  I'm wondering about this as a safety measure for high altitude / long range flights over the corn fields here.  The type of behavior in which I'm interested can be described as follows:
For long range:
1:..
2:..
3: Go to waypoint B     // lets say 10 miles away
   - Conditional: If you reach 60% battery (consumed 40%), jump to step 6
4:..
5:..
6: Return home
For high altitude: similar check
1: Climb at efficient rate to 10,000 feet    // or more, whatever
   - Conditional: if you reach 60% battery OR if the voltage shows signs of dropping, jump to step 3
2:...
3: Motor off and glide back to home
The main reason I'm wondering is battery integrity.  If it gets cold and only provides 4000/5000 mah capacity, then the plane would endlessly try to climb (and crash with no motor), or keep heading to a distant waypoint even though the turnaround point has been passed.  The main culprit?  Cold, aging battery, whatever.
Thanks for your help!
  Adam
