Analog RSSI from cheap 915MHz radios
I would like to build a stand-alone telemetry tracker based on the analog signal strength of the incoming signal. I plan on using a relatively large DISH antenna or 4 YAGIs, and 4 receivers .  The signal strengths would be tested against each other, and the antenna would be turned accordingly.  In order to do this, I need 4 or 5 inexpensive 915Mhz receivers that output analog RSSI data.
Does anyone know of such receivers, or know of a modification?
  • OpenUAS said:
    Si1000 based modem with SiK opensource software the 3DR "clones" see https://ardupilot.org/copter/docs/common-3dr-radio-advanced-configu...
    So you asked for analog RSSI, good on the Nice RFD900/868 there are I/O pins left else on those $20 cheap modem one has to solder a wire to an I/O pin on the Si1000. I recall in the source ther was "AT+P=x set power level pwm to x immediately".  https://www.instructables.com/id/Analog-Output-Convert-PWM-to-Voltage/. Make sure you disable dynamic TX power levels BTW.
    Have some 6 Xtend gathering dust,  they have analog RSSI pin, send me a PM you can have m for free.
    XBee's also have PWM RSSI out... Also there I have quite a bunch you can have.
    I would love this!  I tried to PM you but couldn't because I'm not your "friend".
    I would like to build a stand-alone telemetry tracker based on the analog signal strength of the incoming signal. I plan on using a relatively large…
  • Si1000 based modem with SiK opensource software the 3DR "clones" see https://ardupilot.org/copter/docs/common-3dr-radio-advanced-configu...
    SiK Radio — Advanced Configuration — Copter documentation
