I was wondering if there was a simple built in way of streaming the GPS data of the plane out of Mission Planner into Plugin software to drive a RS-232 Antenna Tracker system?
The info that is needed is Latitude, Longitude, and Altitude. I have a friend that is willing to write a basic Plugin to communicate the info to the serial-Servo driver.
If this info streamable from Mission Planner that would make it easier.
Any insight into this would be helpful...
Michael, i've just received my Micro Maestro 6-channel servo controller, just got it on polulu tester for the 2-axis antena tracker, i haven't even connected it on mission planner. But i just got an idea, that might be very easy to put in practice, and would be very cool to have.
my idea is simple: as we only use channels 0 and 1 for pan and tilt, can channels 2-5 be used as analog gauges? i thought abou adding airspeed, battery % (with help of attopilot sensor), altitude and climb rate. maybe other parameters could be added for user selection, as flight modes.
this way, we can add servos with pointers on their arms and have analog gauges on our ground stations, similar to an aircraft pannel, and these will be very visible on bright sunlight. i believe we all use notebooks as ground stations, and the sun is always an annoying thing to deal with when trying to read something on the screen.
This is an awesome idea!  I'd be all over this in a hart beat if support is made for it.
press control-G for nmea output.
the planner does support antenna tracking as well.
It sure does!  It took some time to get the azimuth and elevation angles correct (with the servos I modified) using the HIL but it works like a charm now.  Thank you for your work Michael.
michael, what about the analog gauges? is it possible to have them running at the same time as antenna tracking?
my tracker is already working on mission planner, it is really cool and user-friendly to get it to work properly!
Ricardo: would you like to share  your antenna tracker setup like mechanical and software setup also? Because mine was not work properly yet.
Regards
Hello Colin,
I am looking to use my APM 2.5 which i dont fly with anymore to build a tracker for my RFD900 Long range Modem.
The Wiki page has given more questions in my head than actually were...Would seek ur kind advice..
Thanks in advance!!
Hola Ricardo.
no se si estas usando pololu maestro para controlar tracker, pero estoy interesado si es asi en conocer los valores puestos en mission planner para control de tracker por que mi servo 360º de pan no para de dar vueltas.      saludos
Ricardo Affonso said:
Michael, ¿qué pasa con los medidores analógicos? ¿Es posible tenerlos funcionando al mismo tiempo que el seguimiento de la antena?
¡Mi rastreador ya está trabajando en el planificador de la misión, es realmente genial y fácil de usar para que funcione correctamente!
