APM 2.0.17 NO WIZARDS!
I am running APM 2.0.17 on MAC and I am not seeing the mandatory setup wizards. Searching around I see a similar problem from A YEAR AGO and wonder if this is just how it is?
http://diydrones.com/group/arducopter-y6-owners-group/forum/topics/initial-setup-wizards-in-apm-planner-and-initial-rtf-y6-motor
Please help! I dread the idea of buying a Microsoft product so I hope to find a fix for this.
Thanks!
    There is also basic documentation here on using the planner to get started http://planner2.ardupilot.com
  • First timer so I like the Wizard route.
    Just to be clear I am using and the problem is with APM not MP!
    • Yes, sorry - my bad. Just remembered another thread that complained about wizard resetting too much.
      Luckilly, there is no wizards yet,   - wizards are dumbed-down version of stepping thru essential configuration steps.
      APM planner is very nicely arranged, you you just need to look into every item from top to bottom:
      Install desired firmware first.
      Then connect , click "initial setup" , then go thru all items in "mantadory setup"  - you've done whatever a wizard would do.
      Then proceed to "optional setup" - and configure whatever applies.
      - done :)
      • I've installed firmware successfully.
        The next button down is "3DR RADIO" which displays a host of different fields between "LOCAL"and"FIELD" radios.
        Is "mandatory setup" a button like "Firmware" and "3DR Radio"? I only have the two buttons present.
        Thanks !
        • Connect, then you'll see the rest.
          • Connect USB-Pixhawk or USB-Telemtry Radio?
            • That's entirely up to you :)
              57600 is baudrate for radio , 115200 for USB cable
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
