I have been building my own version of the arducopter for the last few months and have run into some trouble..
My first problem was that it was overpowered and spun out of control when trying to compensate for wind, this seems to be fixed since I set the PID's for stabilization (which is the mode im in) to
Stabilize Control P (Was 4.5, set to 2)
Yaw Stabiliza Control P (Was 4.5 I think, set to 2)
This has allowed me to fly without crashing very successfully..
However, Im not sure where to go next, my friend has the DJI Naza and had a very similar experience until he bought a gps and used something called "GPS mode"..
I have the ublox-LEA GPS but I dont think its actually doing anything when Im in stabilize mode.. When I set the throttle and leave the other stick in the middle position it allways drift away. It doesnt even try to stay in one place..
Am I missing something, does the APM 2.5 not have this functionality ?
I have seen many videos of people releasing their radio and the quad stays firm in all kinds of weather, how are they achieving this ?
PS: I also have the 3dr radio and used it to make sure the GPS has a fix..
Also, sorry if this was posted in the wrong category.
Best regards,
Alex
It seems there is a lot in the Wiki that you need to read.
If you follow the Wiki index on the left and go through the steps of building, hookup, setup, calbration, etc you will have all the functions you could hope for.
That includes position hold, loiter, waypoints, etc.
RTFM  ;-)
Indeed, for the copter to stay in the same place, you need to toggle a switch on your receiver to put the copter in loiter mode.
But seriously, read the wiki.
Ofcourse, I am reading the wiki, just wondered if there was something I was missing.
What about the fastening of the board, I read that it needs to be able to move slightly (the gyro).
How soft surface does it need?
I just now realized it tilts a little depending on how the cables are organized... Could this be the problem?
What kind of material should I use under the board ?
Start checking out very thoroughly the horizontal alignment of all your stators (motors). Constant drifting away often has to do with a poor alignment of one or more motors. Difference can be like day and night.
Try reading the forum post about firmware 2.9.1. There is talk about different material and how to place it and how test if you get it right. First balance props and motors. I used foam rubber just under corner of my APM case. Do a test flight with RAW logging turned on and check Accel Z values. Good luck and fly safe.
