Has anyone successfully used the APM2.5 (or other APM) with the cheaper NEO-6M ublox gps ?
Did you need any modifications to the source code ?
Thx !
Thanks. I just flashed the file on to my gps.
I wonder: Some values are a bit jumpy
Altitude: 245,3m - 270,4meters
2D Acc: 2.55 - 3,6
All the time my gps module is lying next to my window.
I have the Ublox 6M-Neo GPS which I got form RCTimer and have used previous for my CRIUS AIOP v2 board, and I was wanting to use it on a APM 2.5 board. I'm having problems flashing my board with the ublox.txt file provided in this thread with the u-center software.
I made a usb-FTDI cable with a FTDI adapter, wired it as I was supposed to, but can't tell if I am really connected to the GPS. The com port created when I attach my cable to the computer running windows 7 is recognized by the u-center software... Though, I'm a little dyslexic and for some reason have problems with the whole TX-RX reversal thing, but I sketched out the wire layout so I'm pretty sure I got it right.
When my cable is connected through the header pins to the GPS it powers, the red RX led on the FTDI adapter flashes about once every one to two seconds. There is no GPS fix indoors or out indicated by the u-center software.
When sending commands or a file to the GPS, the green TX led flashes ever so briefly. In the configuration upload window in the u-center software (v 7.02,) I get timeout errors saying the receiver isn't acknowledging as the file uploads a line at a time.
Some threads say this the error is normal, but when I connect the GPS to APM 2.5 board it is not recognized. I'm not confident anything has happened.
Oh yeah, the com connection indicator at the bottom of the board does flash green when the GPS is connected and I have tried various baud rates, making sure the com port in Windows device manager is configured at the same speed.  I have tried the configuration file upload process with the TX-RX line reversed, just in case my dyslexia has gotten the better of me. Still no joy... Is there any other way to confirm connection of the GPS to the u-center software or other software?
I'm building my first quad and would just buy a compatible GPS to the APM 2.5 but burned up $65 worth of ESCs, somehow, and I need to replace them first, but I'm getting really frustrated.
Any help is appreciated. Thanks.
Hello,
I live in Germany. You could send me your GPS and I flash it for you.
If you're running a six wire FTDI Cable the colors are not one for one
This is the correct pin Association
On the FTDI cable the black wire goes to the RC timer greenware the red wire goes to the Rc timer black wire the org wire goes to the yellow RC timer wire and finally the yellow wire goes to the red rc timer wire
Also use autobauding in u center
On the left side is the FTDI cable and on the right the connector to the gps module.
Or just use the one used with APM2.5.
the coloring is different is all rong
look at the white end where the GPS connector the colors are different from the apm. coloring
I use it on my apm2.5 and it works perfect. I got mine from hobbyking. I just uploaded the 3dr firmware and its plug and play. Here is my video http://youtu.be/_hx5k1ohHx8
Do not use the 3dr it is Optimized for aircraft not multi-rotors to help loiter use the file I attached..
I don't see the file
