Has anyone successfully used the APM2.5 (or other APM) with the cheaper NEO-6M ublox gps ?
Did you need any modifications to the source code ?
Thx !
Sounds like there's no issue since it worked outside right next to a building (balcony sounds like an apartment - brick).  My rctimer ublox works great inside my house.  8-10 satellites.
nah an the neo 6 is great,         i use it under two floors and i still get a 6 sat 3d lock.
You should bbuy some of those white to white plugs and plug the gps and telemetry into their dedicated ports
What? They come with the plugs attached....
which plugs do you have, white to white or white to black?
I got White ti White 5 pin plug in both the module
This is my set up may be someone can spot something wrong and help me out to sort my problem out
what the heck kinda gps do you have?
thats not normal
also gps only uses 4 wires
Has got only 4 wire and it's neo 6m 0 001
Edit it's got 5 but only 4 are used
Is there a white plug on the gps receiver itself?
No, is GPS antenna to GPS board, and from here there are 5 pins going to the APM with the pigtail with the white plug
Any thought about what could be the problem?
I took out my F550 power distribution board and rewired using a custom power breakout connection using solder.
This solved my issue. Look into EMI issues with power and possibly other things
