I ve been flying a quadcopter with apm 2.6 for awhile now. But recently it started acting weird. It keeps landing on its own all of a sudden. Its totally well within range , in fact all the times this happened, the drone was within 10 meters from me. Today it crashed all of a sudden and i figured the mode has changed to LAND after going through the logs.
Please someone help me understand this. I will attach the log files i dont really know how to read those.
Thanks in advance.
2016-03-15 16-22-31.bin
2016-03-15 16-22-31.log
2016-03-15 16-22-31.log.xml
  • Direct from Mission Planner/Analyse Log:
    Log File C:/Users/UAVS/AppData/Local/Temp/tmp564C.tmp.log
    Size (kb) 421.1748046875
    No of lines 6185
    Duration 0:03:14
    Vehicletype ArduCopter
    Firmware Version V3.2.1
    Firmware Hash 36b405fb
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Test: Autotune = NA -
    Test: Balance/Twist = NA -
    Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 5.54m
    Test: Compass = GOOD - mag_field interference within limits (0.85%)
    Test: Dupe Log Data = GOOD -
    Test: Empty = GOOD -
    Test: Event/Failsafe = FAIL - ERR found: FS_THR
    Test: GPS = WARN - Min satellites: 6, Max HDop: 3.69
    Test: IMU Mismatch = NA -
    Test: Parameters = GOOD -
    Test: PM = NA -
    Test: Pitch/Roll = NA -
    Test: Thrust = NA -
    Test: VCC = WARN - VCC min/max diff 1.25v, should be <0.3v
    Not so sure about the brownout assumption because the log ended at altitude, as I am currently trying to find the cause of a crash I had which says the same thing but is not the case as I have dual power supplies and little voltage fluctuation.
    2 Points:
    Test: Event/Failsafe = FAIL - ERR found: FS_THR  is worth following up on. Radio signal or Tx problem?
    then
    Test: VCC = WARN - VCC min/max diff 1.25v, should be <0.3v  could this be causing the Rx to stop?
    and
    Test: GPS = WARN - Min satellites: 6, Max HDop: 3.69 but you weren't flying in GPS modes so that should not cause a land.  What FS settings do you have?
    Radio issues seems to dominate the log at the point of crash, but I am not that experienced at reading these.
xemone liked Max Gilson's profile
Aug 31
nick rymer left a comment on ArduCopter User Group
"I recently switched laptops and now have Windows 10. I installed Mission Planner on my laptop and plugged a mRo SiK Telemetry Radio into the USB port. The radio is not recognized on the com ports but is instead on the "Other Devices" tab in Device…"
Aug 20
