APM2.5 5V/Vcc Schematic
Frequently asked questions are about powering an APM2.5 or why the same does not work or why it has failed.
Here is a simplified schematic showing the major components of the 5V/Vcc circuit on the APM2.5
Target Audience: Readers who do not have Eagle or are confused about using it.
You Need: Basic electronic schematic reading ability
3690968635?profile=original
Note that I have separated the PWM Output section into the upper left corner with a heavy purple line that is bridged by the jumper JP1 on the APM2.5. This is to emphasize that diode D1 passes current through JP1 (and drops voltage). The remaining energy is then called 'Vcc'.  Everything outside the purple corner is Vcc.
This is why the USB will power the APM2.5 when connected to a computer/USB hub. Note the fuse on the APM2.5 side of the USB connector AND another fuse on the output of D1. Another change from APM2.0 is the D4 6.0V Zener diode. If an over voltage is applied to the board, D4 will crowbar what it can to protect devices.
As with APM2.0, any 5V source connected to any of the indicated Vcc/5V points outside the purple corner (with GND of course) will power the APM2.5.
Also of note is the 'Mystery Port'. This port takes 5VDC before D1 and the fuse and is called 'JP_VCC'. Other clues to the mystery are the lines to 'ADC 12' and 'ADC 13'. A mystery indeed!
Any errors in this drawing from editing are mine.
I hope this can be used as reference for solving problems.
-=Doug
27-FEB-2014 Eagle files are now located HERE
  • Good question. I seem to remember seeing the file listed after the 'mystery module' was revealed. Where is it now?
    With the 'new' technical forum running, it may be cross linked over there somewhere. It may have been linked somewhere in this thread after the reveal.
    -=Doug
  • Hi,
    Can I get a reference schematic for the 3DR APM2.5 with XT-60 Power module.
    Thanks,
    SS
  • Hi
    On the power module, the big smd capacitor, what is the capacitance? it blew up on me, and I want to replace it.
    thank you
    M
    • I checked my operational Power Module and if you are referring to the large yellow SMD cap, the numbers on mine are '107 25 310'.
      I do not think I have a schematic of the PM. You should be able to find one somewhere on the net.
      -=Doug
      • thank very much, this should do :)
  • I am installing a new cx20 open source FC V252 V5.0  and need a pin out of the connections, especially the connection from the GPS.  Can anyone help?
    Donn
    • I do not understand which connections you are looking for.
      This thread is to help with the +5VDC distribution and the upgrade to the Power Module (PM) addition to the APM 2.5/6.
      Are you asking about another flight controller?
      -=Doug
  • Exactly what BEC (actually just a DC to DC converter) are you using? Does it have jumpers to set input/output voltages?
    What is the battery voltage on the red and black BEC input wires? (connect your meter to the red and black input)
    Remove the cable from the HK radio to APM and measure the voltage on the BEC output wires, red and black.
    Would the hobby shop you purchased the items from be able to assist you if you took the aircraft there?
    -=Doug
      The only reason for the voltage to fluctuate is if there are two competing voltages connected together. Can you provide a more complete diagram and or pictures showing the wiring?
      • Dear Bill,Doug,
        sorry for my late reply but I was away from home for business..
        I attach a picture that shows a more complete connection diagram (sorry for the quality). I did try to fly the quadcopter as it is as the Vcc value now is in an acceptable way if you also agree..
        3702724329?profile=original
        I also attach my yesterday;s flight log file. I would appreciate if you could give me your feedback as you are more experienced.. What I understand is that my quad is in the limit of its payload ability. A few more grams and it will be overweighted for good.
        Also, can i be confident with y mechanical parts (motors) that can fly for many hours or do I have to replace them every some hours ??? I have DJI E310 2312
        Best Regards,
        2015-10-28 00-17-34.log
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
yesterday
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Monday
DIY Robocars via Twitter
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Monday
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Saturday
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
RT @SmallpixelCar: #CUDA implementation should be easy, because most of the time is on distance calculations berween two points and if the…
Jun 25
RT @SmallpixelCar: This is the view from the car. Even my lanenet inference is fast on @NVIDIAEmbedded Jerson Xavier, DBSCAN clustering tak…
Jun 25
