  • R.d. I have a loop used for inspecting micro printing, will give that a try.
    Thomas, the reset switch seems to work. It will reboot, but the red light that shows armed never comes on. Other lights all work.
    Thanks for the suggestions. I will post if I find a fracture. FYI it is the APM 2.5.
  • Admin
    @Quad Papa,
    Make sure that the reset switch is not stuck in the closed position.
    TCIII
  • You probably fractured a solder connection or solder trace on the pc board.
    Do you have access to an inspection microscope?
    You could inpsect the board carefully for fractures.
    -=Doug
