Jason is travelling this week, so I'll take the helm for the next software release post.
UPDATE: the motor remapping thing was confusing everyone, so we took that out and returned to the regular motor mapping. That means that APM 2 users with Hexas and Octos should wait for the next version. APM 1 users should be fine with any frame.
NOTE: Hexa and Octo users: there have been motor mapping changes that may affect you. Please don't upgrade until we can update the documentation to reflect the changes. This should happen by the end of the day today (Feb 1).
ArduCopter 2.3 is now available in the Mission Planner.  This is the next revision of the ArduCopter 2.2B6 code, which is perhaps the most tested code we've ever released (1288 comments in the thread!)  and certainly in my experience the best code, too.
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P (default is 0.14, so start by turning it down to 0.1. In general tune PIDs in 25% steps).
Now that we've got solid code out there, we can turn to collecting suggested gains for standard frames, and a better guide to how to tune PIDs for your unique setups.
Here are Jason's note on the latest changes (mostly from 2.2B6)
A dampening term called STAB_D has been refined. A D term for all of the Rate based control loops has been added based on Igor's work. Landing for Baro and Sonar has been refined based on JLN's work. A slightly new approach to Loiter and Navigation is being used to try and linearize the pitch and roll for rate control. It tends to use lower gains, yet has a more assertive response in the air.
STAB_D : This is the gyro accretion dampener. This can remove small wobbles during sharp changes in angle commands. Making this too high can have a negative effect in performance and add a memory effect that can cause temporary loss in control. The in flight tuning is ranged so you are just below that effect.
If you haven't noticed before the control loops are in two stages. The first is a PI stage that converts some sort of position or angle error into a desired rate. These generally do not need to be tuned. They are more of a user preference on how fast you want the copter to perform a motion.
The second stage is the actual PID loop that needs to be tuned for the copter. This converts the desired rate into a motor command of some sort. I added a D term based on Igor's recommendation to the PI's for each rate controller. These should show up soon in the mission planner for the release. I cannot give you a concrete answer for how to tune the D terms, because they each depend on their function such as alt hold or loiter, etc.
Still, the absolute most important term is always the Rate_P term for each loop. Start tuning here.
The default PIDs are in the what flies great for a stock jDrones/3DR Quad with the purple motors in X mode.
Note the Mission Planner does not yet highlight these D terms on the main tuning page (it will soon), but you can find them and modify them on in the Parameters list.
Autolanding should now work well (see video above) and the Tri servo issue is now resolved.
The code should now compile with Arduino 1.0 (thank, Randy!), but remember that you need to use the "relaxpatch" version of Arduino in our downloads section
[Update: we've reverted the below. See update at the top of the post]
Important for Octo users:
We've changed some of the motor orders for some more exotic airframes. We'll be updating the docs on the Wiki in a day or two to reflect this. Pat Hickey explains:
As before, the hexa plus APM2 motor setup has changed from the ordering [1, 2, 3, 4, 5, 6] to [ 5, 6, 1, 2, 3, 4 ].
The Octa V layout for APM2 is:
6            4
  2        5
    8    1
      3 7
Motors 1 through 4 spin clockwise, and 5 through 8 spin counterclockwise.
Support for roll/tilt camera control on APM 2 should be coming in the next version. Traditional Heli will also be updating to this latest code as well once we track down a memory issue.
As always, you can see a complete list of changes in the changelogs.
Thanks for that info, Randy!
One might also add that a failsafe issue has been fixed, as Jason reported in another thread.
Looks promising.
Tomas
Martin,
I have tested auto takeoff a couple of times.
The takeoff and climb out was very hesitating, causing the copter to skid around on or close to ground, slowly establishing a climb. Maybe this can be tuned using some parameter? (I don´t know)
Tomas
Hey Hein, thanks!
PID are all pretty much stock, STAB_P 4 / STAB_I 0 / RATE_P 1.50 / RATE_I 0 / STAB_D 0.08 / all other D terms at 0
We use Aurora 9 for flight control and dx6i for camera mount, both 2.4Ghz
Hi Angel, with the latest fix on GIT the loiter work much better, your mod is based on the latest version of GIT?
No Angel, is the old GIT.
Now i've implemented your mod in my local 2.3.1 beta, testing now and I write my impressions on the dev list, we do not publish here the last git for now.
Bests
Marco
Marco Ive done some rework on my frame and fixed some tilted motors so tomorrow Ill take it for a run. Can you please look at my settings and recommend anything I should change?
Angel, there's a little error in your doc, in config.h "LOI__IMAX" with double underscore... :-)
Hi John!
I suggest you wait for 2.3.1, which I think will be shortly released, and you you want change your X8 motors respecting the new connections, I've already done with mine.
Obviously
if you want to continue using it as a "X QUAD" with esc in parallel mode do not do anything about this.
http://wiki.ardupilot-mega.googlecode.com/git/images/APM1/ACM-X8_AP...
Marco Whats the main advantage to have the 8 motors  independently controlled? I suppose one advantage is the top and bottom speeds can be different now to help counter the wash the bottom props sit in?  The mods to change it over will take me a bit of time so for now Ill leave it as a XQuad for tomorrows test flights. Will 2.3.1 be out today? Im GMT+8
There are several improvements on 2.3.1, I suggest you wait for the release, we're completing the tests, i hope likely in the evening.
Yes, the advantage is the top and bottom different speeds,
could improve flight attitude and yaw control, but you're not obligated to do so.
Angel, some reports from AeroSim: the pid for loiter work fine, but anyway all the stabilization and rate pid however affect the loiter, try to greatly increase Stab P and you realize right away, is not really separate.
Sure that affects, since I didn´t change the global logic of 2.3.  I´ve only separated the pid parameters of the loiter "pid" control loop part. That´s it.
The way the copter is stabilized inside loiter is still the same than 2.3, controlled by the stabilize part of the code (it could be done also an specific "stab code" for when in loiter, but maybe that´s too much...)
Thanks, Marco, for your comments.
Angel
