Arducopter 2.9 for TradHeli Discussion
I am opening this topic to serve as the go-to place for talking about the upcoming 2.9 software release for Trad Helis.  I think this will be necessary as 2.9 will have SIGNIFICANT changes in the way that the helis fly, and also in the settings you will use.
Yesterday, I flew 4 packs of "2.9 - rc2" from the downloads section on my 450 heli.  The file is located here:
http://code.google.com/p/arducopter/downloads/detail?name=ArduCopter-2.9-rc2.zip&can=2&q=#makechanges
I would be interested in having some other people try some test flying with this.  I'll have to walk you through the setup, as it requires a bit of work to get a flying parameter setting using the rate controllers which are now active.  You CANNOT fly using the old parameters for Stabilize PID.  Don't even try it.  Also, the Alt_Hold parameters will have significantly changed.
This is slightly complicated by the fact that we have some new Heli-specific Rate PID parameters called "Rate_Pitch_FF", also for Roll and Yaw.  Unfortunately these are only accessible in MP from the Advanced Parameters List.  Hopefully I can get that fixed.  What I'd like to do is for TradHeli, in MP, remove the Rate_Pitch_D, in the Config PID screen, and replace it with Rate_Pitch_FF.  This is because I have found the D-term to be completely unusable anyway.  The FF is feed-forward.  This was what I found was the key to getting the heli to be able to fly in rate mode.  Basically, it is like P-term, but has no error correction.  It's sort of like this:
P-output = P-term x (Rate Input - Current Rate)
FF-output = FF-term x Rate Input
then you also have the I-term output.  So the total servo command is:
Servo-output = P-output + I-output + FF-output
I have also implemented the FF on the yaw controller, and found that it actually helps to stop the slight "tail wag" that we always had.
There are also some new settings for the collective.  These are Stab_Col_Min and Stab_Col_Max.  What these are for is sort of like Idle-up pitch curves.  You can now set up your swash plate with full negative pitch, maybe a range of -10° to +10°, or +/-12°, but when flying in Stabilize mode, you can set Stab_Col_Min to reduce the amount of negative pitch available to something like -3° or whatever you prefer.  This gives a nice soft feel.  However, in Acro mode, you will get the full range, and also the auto-pilot modes get the full range.  For example, I set my Col_Min and Col_Max to give me +/-10°, and then I set Stab_Col_Min to 40, which is 40%, and this changes the negative pitch to only -2° in Stab mode.
The only thing to know here is that when you change modes between Acro and Stab, the swash-plate will jump up and down, so you have to be ready for it.  It's no different than using Idle-up in your Tx.
My test flights yesterday went quite well.  The Alt_Hold now works beautifully, and I actually prefer landing in Alt_Hold rather than Stabilize!  I also did a few flips with it in Acro mode (very ugly, I'm not good at this) using full negative collective when upsidedown, and it worked well.  It didn't seem to get confused.  Finally, I tried going into Acro, rolling it over upside-down or sideways, then back to Stabilize, and it flipped right way up which is good.
The only problem I have seen so far is that when flying in Alt_Hold, if you push the cyclic full forward and get up a high speed, the altitude starts to oscillate badly.  I suspect this is a classic "phugoid", or pitch/throttle oscillation.  We'll have to work on this. However it seems to fly well up to about 1/2 Vmax.
I'll try to post my Parameter file here tonight, but I caution that the settings will be HIGHLY dependent on your servo speed, as well as many other setup differences.
  • dupe, deleted.
  • Just setting up my first APM trad. Heli, a FLB Trex-450. I just flew it on the default P1.4 rates... wow that was scary! P is now down to 0.040, and it can actually fly now :) however I have very very little control.
    Quick question though, I've noticed that all 3 swashplate servo's drop to "minimum" or -24deg pitch and bind a little. I have tried to set the min and max swash servo values but on power cycle or mavlink refresh they default back to 1000-2000. Just wondering if this a known bug or am I doing something wrong here?
  • Hi R_Lefebvre,
    what rate and alt_hold PID values did u use on your 450 Heli with the asymmetric spinblades you showed up in your "alt_hold demo in stormy wind" youtube video?
    Or has anyone a hint where to start PID tuning with those asymmetric blades?
    Thank you.
    greetings
  • Hey Rob, I posted this here because its not really a dev issue.
    My COLYAW is linear --- not V-shaped like it should be, always has been. Except for about 2 flights. I think its a bug with the code, but might be a setup issue. Remember ages ago I was saying I need to make COLYAW negative for it to operate the right direction? That still applies, but it is only correct for positive pitch. I had a look at what was causing it in the code, but I cant seem to figure it out.
    Thanks for any help
    Joly
  • Im using a DX8 and Im wanting to know what the gyro settings do to the Arducopter controller? For example, I have my Gyro normal set to -75. I found that if I go below -70 i cannot arm the Arducopter and i get no pitch or throttle. As soon as I move it back above -75 or so it works fine. I have a tail wobble side to side in a very quick manner like have a very high gyro gain with an 401 gyro.
     So what does the gyro gain settings in the radio do to the Arducopter?
  • Need help with the roll correction on my heli..
     When I roll the heli in my hand the swash plate corrects in the wrong direction.
     Any idea why this is?
  • Not sure if it matters or not, or whether you are aware of this already, but I noticed that in 2.9.1b the extrenal gyro gain is impossible to get realistic PWM output when using ch6 tuning. The max I could get was 32 PWM. I changed the term "tuning_value" to "g.rc_6.control_in" in ArduCopter.pde and it works ok
  • Hello people, what are we doing to limit cyclic pitch currently? Is it IMAX?
  • Got the 600 up and flying again yesterday, had to go back to training gear to sort out some PID issues. I tried using a parameter file from the 2.7.1 I was using and that resulted in no pitch/roll? So I ended up just inputting the swash servo trims and PID's manually without the parameters file. That got it in the air but it had a serious oscillation issue, had to back the P terms to 2 from the 4.5 it was with the old firmware. Any idea why?
    Also where do I adjust the FF terms? I need some agility back...
  • Hey guys, sorry for all the confusion, but I think there's really no need for you guys to go through all those steps and configuration changes.  That was mostly during the early days when this setup wasn't mature anymore.  You should not need to worry about compiling with Arduino IDE, nor worrying about Config files or any of that.
    You simply install the APM, plug the USB cable in, and load it with 2.9.1 directly from Mission Planner.  Then you just need to tune your PIDs.  Pretty simple stuff.
    Jeff, sorry, I don't know anything about Optical Flow setup.
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Tuesday
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Jul 6
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @chr1sa: Here's today's best times in the @DIYRobocars/@donkey_car virtual race of AI cars compared to last month's race on the same tra…
Jun 20
https://t.co/0Fovk6MCsp
Jun 19
The difference between proper RC cars and toys (when you’re turning them into robots) https://t.co/79wP3fMCCh
Jun 14
RT @Struktur3D: We have just posted on @DIYDrones for the first time in a long time. Continuing with our search for a #lasercutting service…
Jun 5
Review of the new Nivida Jetson NX for robocars https://t.co/bWjd3sH2o4
Jun 2
RT @chr1sa: Somehow I missed this, but last week @Nvidia released a new version of its Isaac robot development framework. Lots of new Lidar…
May 31
Welcome to the new DIY Drones design!. You may have noticed that DIY Drones looks a little different today. That's… https://t.co/cg2EmeDGMQ
May 27
New! Online Training on Drones for Disaster Response https://t.co/brqRuujjY2
May 26
RT @chr1sa: Our next @DIYRobocars autonomous car virtual race is this Saturday. Sign up here to compete or just spectate on @Twitch https:/…
May 19
Definitive Guide to Setup Drone Delivery System https://t.co/7ibwcgF24h
May 19
Fighter Hand throw fixed wing https://t.co/cwBPSsbePp
May 15
