Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Nice job Randy and everybody else in dev. section
I have fund away reproduce CLI gps test  bug.
I use AC3.0.1, MP 1.2.60 ,ublox6 (with 3dfix on) :
goto CLI -> Connect APM(button) -> type test, then gps
it will show :    3Calibrating barometer///e8erehylhdeigvhdgvd (ALOT OF CRAP TEXT)
Hit Enter 3 times (it stop)
Type test -> gps , now it output correct, no crap text
screenshot link
https://dl.dropboxusercontent.com/u/17103005/CLI_gps_test.jpg
Hi Randy,
Congratz for the new release..
How about ROI, is it fixed on this release?
Really kinna required ROI feature now..
Thanks.
Waladi
Wow! Loiter much improved with SimonK esc's! I don't know how many hours I spent trying to kill the SimonK wobbles but they seem to be gone now. Congratulations on the great work!
Here is a video of Loiter 3.0.1 in winds 12kts gusting to 15kts... 880KV motors, 3dr quad frame, Next Level Simonk 600mhz esc's, GemFan wood props 12X4.
http://www.youtube.com/watch?v=zGaowHfn_s0&feature=share&li...
Steve
Thanks.  I like reproducible behaviour.  We can fix this.  It looks like the GPS test is resetting the APM.
I'm putting all responses from the original AC3.0 thread here to help drive this thread higher on the Top Contents list.
David Ardis asked me to look at his vibration levels and they are a-ok.
Do I have to re-do my set-up when going from AC-3.0.1-rc1 to AC-3.0.1?
Stefan Gofferje asked:
Question 1:
Does Arducopter 3 now autostart the MAVLink streams as they are configured in the parameters? Or is it still necessary to send a stream start command via telemetry?
It's a bit unpractical if you don't have a laptop and want to just go FPV-flying using MinimOSD-Extra...
Answer: push this button in the mission planner
Question 2:
How important is the vibration issue REALLY? I mean, is AC3 totally unflyable with vibrations? What's the absolute limit?
Answer: keeping vibration levels low is very important in order for the inertial navigation alt and position estimates to remain accurate.  The acceptable range for Z axis is -15 m/s/s - 5m/s/s, for X and Y axis is -3m/s/s ~ 3m/s/s.  There's a graph just above which shows the output from the dataflash for someone else and includes the lines which your vibration levels should be within during a stable hover.
Great work Randy, Craig, Mr Oborne, Marco and everyone involved in the development. My loiter is rock solid, simonK esc's and all :)
Loiter- http://www.youtube.com/watch?v=IeHcH00gJoQ&feature=c4-overview&...
auto land after RTL- http://www.youtube.com/watch?v=mlQZpdyiAW0&feature=c4-overview&...
No.
Waladi,
    Not fixed yet but it'll be fixed for 3.1.  sorry!
Mike,
     Yes, that was a minor change that I didn't mention in the release notes.  As Eduard says, accel offsets of up to 3.0 now pass so I think you will be ok but sadly Eduard's are closer to 3.5 on one axis so I've generated a custom firmware for him.
One more fpv/minimosd video showing two short Loiter segments in a 20mph gusting wind using 3.0.1. Check out the "HA" (Altitude) shown on the right side of the screen. Loiter holds even in the heavy gusts. Also interesting is the vertical speed changes shown to maintain the altitude.
http://youtu.be/AjVfTgPIX74
Thanks developers! This is an absolutely terrific release!
