Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
I didn't use it since a very long time. I remember i had reliable results for terrain following at a couple meters altitude. I remember that i had single spikes from time to time in the logs but they were filtered by the code.
Because of the hard acoustic environment on a copter, it will be difficult to get good results at more than perhaps 4 - 5 meters altitude because of the degraded signal / noise ratio.
For better signal / noise ratio results a very directive sensors would be better, but it will need a small gimbal...
I did use thin foam from a MP3 player helmet. Around 0.5 mm thick. It is directly in front of the sensor, not on the horn. Adding a second foam on the horn entrance could help even more.
If you listen for a condenser microphone in the wind without windshield, you will understand what's going on in the ultrasonic sensor. The same thing happen for sure.
For sound capture in the field, we always use windshields, sometimes two layers when there is a lot of wind. And we activate a low pass filter (40 Hz to 100 Hz) directly on the microphone to clean the signal before it does enter the microphone preamplifier. We do that because the wind is inducing high level of low frequency content (even with the windshield) saturating the amplifiers if there is no protection.
Olivier
Thanks i get the general idea, i was just wondering how much or how little foam and where to locate it. I was not really sure how well the waves can handle passing thru foam even if its not dense.
I saying all this, how about the optical sensor? I know its not working in 3.0.1 but I don't see very much info around on how well this works and how accurate it is compared to the sonar. For low level flying accuracy between 0-2 meters I would have thought this would be a logical choice to develop fully don't you think?
do we have anyone with some good testing data and information about how stable and accurate the optic sensor is? I would be interested to hear more on this option.
They do different things, I thought? Sonar gives height hints, optical flow gives lateral position hints.
ok, so then using both should in theory be able to give a loiter hold without GPS? Has anyone done this?
Thank-you Randy ...  That was very helpful.  I'll adjust my line of thinking when using the conditional commands.
Jamie
John,
     I've used it numerous time although mostly just for testing.  I can't really say that it works as well as a GPS.  Videos are here and here.  In the future I hope to combine the optical velocity with the inertial navigation to make it all more seamless and resilient.
Dustin,
     So if you disable the fence through the mission planner, and start with the switch in the off position then you should be good.  Basically as long as the switch position matches the set-up in the mission planner then you'll be ok.
     By the way, I think we're going to remove the ability to enable/disable the fence for 3.1.  The thinking is that it just adds a layer of potential problems giving people the ability to easily turn it on and off.  We'd prefer if instead we can get to the position where everyone just leaves it on all the time.
re. Sonar
Today I have a "horn" set on the sonar and made ​​a layer of foam at the mouth. Unfortunately, this has also been unsuccessful.
For the graph I fly in about 2m height
regards Peter
There goes the config.
You create a new model and you spend 11 menu Select "CLEAR MIXES" and hit menu. In menu 5 configure the following:
CH1 100% AIL
CH2 100% ELE
CH3 100% THR
CH4 100% RUD
CH5 +61% HALF ID0
+35% HALF ID1
+10% HALF ID2
-76% HALF AIL
CH6 100% P3
CH7 100% FULL ELE
CH8 100% FULL TRN
In menu 7 REV put the CH2 In the menu 2 I point out in "beep cnt" T and 3, so that the transmitter beeps to pass through the center on the accelerator and the P3.
With this setting you have to be on Channel 5 flight modes F.ModE and AIL, PIT TRIM to adjust the PID's or the gimbal for channel 6 and two levers for what you want in the ch7 and ch8.
Let me know if it works.
Sorry for the language, I am using a translator.
Alex,
    Seems we've run out of depth on this thread so I'm replying here.  Below is the list of flight modes that I see in the dataflash log.  I suspect these are exactly what you've seen as well.  I've drawn a red line where the impact happens.  It's during that AUTO mode.
