Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Hi Reuben,
Yes, you are correct. Flew my copter today again, no problems in all modes, still can't figure out what happened about the loiter crash yesterday. Nothing is damaged though. Still Learning to diagnose from logs. Will still post a log, if someone can have a look and figure out what happened.
Thanks for the replies Craig and Reuben.
I have a similar problem on my octa-quad, not an octa so I dont know if this is related or not but I thought it worth mentioning. It descends very slowly, sometimes even to the point of hovering at times and at times rising a little.  it also ascends very slowly if I am in loiter or althold. How does your ascend in those modes?
as you probably already know, you really should check your vibration level and run the compassmot :)
John
Hi Randy, ok did alot of testing on the bench
Test 1
Setup.
Laptop running MP 1.2.75  RFD 900 on ground station using a 2cell lipo through a 5v reg.
current quad octo config,
5v reg supply for apm and reciever
another 5v reg for RFD900 (grounds are tied, 5v seperate)
NO SPEEDIES CONNECTED.
RFD settings are 57600, air rate 64 (back to default config)
Connects fine through modem. (no usb cable in sight...)
I can wiggle the vehicle around and see Artifical Horizon (AH) responding pretty quick.
Ok so now I arm the vehicle, and raise the throttle to hover point ~50% and wiggle at similar rate as before..... AH getting limited data though, I am lucky if it moves every 5 seconds.
NEXT test...
Install current firmware (3.0.1) from MP for quad
Std Quad-X config on apm (2.5,)
(this is a same setup but secondary unit to the one above.)
APM on the bench, connected with RX (ppm sum rx, frsky), RFD 900 NOT Connected at this stage....
Connect via USB, ARMED,..... throttle up, no problem (as expected)
DISCONNECT USB, Connect rfd900, Connect, arm throttle up no problem.
Next test Hexi config. ran through same procedure as last one, same results
Now the interesing one.
Std OCTO config.
Connected via USB,.... wiggle and AH ok..... ARM raise throttle and HELLO we have a slowed AH again. much quicker than through RFD but none the less slowed.  Same test through RFD and very unresponsive.
I use these for photogrametry work with many waypoints on missions, It would be nice to find a solution.
Can the dev team do the similar testing for themselves and tell me if they see the same thing... Don't think the type or frequency of modem is an issue, just the fact that it is there...
BTW I am a avionics tech who has been operating UAV's professionally for many years (over10....)
I am pretty sure this is in the code somewhere....
Any help would be much appreciated!\
Cheers
Steve
Test 1
Setup.
NEXT test...
Std OCTO config.
Cheers
Steve
Have you looked the this in the parameters?
Waypoint Descent Speed Target (SR3_SPEED_DN)
Defines the speed in cm/s which the aircraft will attempt to maintain while descending during a WP mission
Range: 0 1000
Increment: 50
Units: cm/s
Here's the URL.
http://copter.ardupilot.com/wiki/arducopter-parameters/#Waypoint_De...
First time in a while that I post something in this thread again. I'd need some advice.
I changed the drive train on my copter. Before I had 2830-800kV motors with 10x4.5 props. Now I have 4822-390kV motors with 15x5.5 props. I didn't change anything else - also didn't retune yet. At first glance, the copter seems a bit overtuned, showing some wobble in ground effect and some bouncing when letting the stick loose from extreme left or right. Otherwise, it seems ok. Loiter without wind is fine, wind in loiter causes slight wobbling and wandering around, although the latter might have been caused by bad HDOP. Forward flight shows partially ugly wobbling.
I do see a massive increase of vibration in the log but it's generally still well within the limits.
Now, my questions:
  • What kind of PID change would I have to expect from this kind of change in the drive train? Rather higher PIDs or rather lower PIDs? When retuning, in which direction shall I rather go?
  • My guess is that much of the new vibration comes from the overtuning, because the wobbling comes mainly with wind in loiter or appears in forward flight. Is this a reasonable assumption?
Logfile is attached.
That's an error from the auto generated parameter docs. There is no SR3 params related to behaviour. SR3 params are for the telemetry serial port
This is a known error. We have not been able to solve it.
OK, my quad is just a little piece of trash I bought just to see if I liked this sorta stuff. I've been flying RC planes and Helis for just over 40 years and decided to give quads a try. Darn, I was hooked. I already had an APM 2.5 in one of my planes so I ordered one for my little junk 100 dollar eBay special. After loading 2.9.1b and flying for a month or so I decided to load up the new 3.0.1 firmware on it. Big improvement. Same day, the little quad was attacked mid air by a large bird. Result, no damage to the bird but the quad was found three feet under in clear water. After drying everything out and checking for what was usable and what was not, I order 4 new SimonK ESC's and a new "Combo" uBlox GPS/Magnetometer.
Man what a difference the off-board Compass makes. We have some guys at our flying club running the Naza stuff and I was always very impressed with the "GPS Hold" and how rock solid it was. They were equally impressed with my way-point navigation ability but not enough to give up their Naza.
Well, that is, until they saw it with the new GPS/Compass. Their Naza hasn't got anything on my little junkyard dog. That thing is unbelievable. I mean it when I say rock solid in loiter. Even in a fairly strong wind you would almost need some type of mark on the ground to see if it moves. Just WOW, and also excellent work on the new 3.0.1 firmware to compliment the new GPS module. Thanks to all who put in their hard work to make this possible.
---Butch---
Hope that this is the correct forum for 3.0.1 questions on traditional heli. I'm flying a Trex-450 and have the APM at 3.0.1. I've tried to set the cyclic servo minimum and maximum values from 1000-2000 to 1100 and 1900. However every time I save / write the parameters and power cycle or reconnect via mavlink they revert to 1000-2000. Is this a know bug or might I be doing something wrong?
How about you actually watch the video James.  Does it look like its flying in an unexpected manner??  Do you think I would really fly over 900' high if I didn't have control over it??  Do you think I would fly that close to my family if I didn't have control over it??  Are you just ignorant?
Thanks.  Still had plenty of battery.  Have the "Battery low" set to come on at 50% capacity so I have plenty of time to make it back.  Been flying since 95
