Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Hi Andre:
Is altitude hold on the APM1 ok?
Regards
tangtl
I am considering ordering a new board.  Maybe the 2.6.  I'm itching to try the autotune. By the way, Is there is a way to enable autotune on rc3?
Hi tangtl,
I havent been able to test ALT_HOLD yet - it's been raining here since the weekend.  Im hoping to test it this weekend if the weather is good...
Yellow led always on. I add logs.
Ok, please see battery FailSafe.
And please what about Acro?
Logs.
Well I just ordered a new 3DR APM 2.6. Hopefully this will work for me.  Oh - also pulled the trigger on an Iris!
Well it certainly is interesting, in my case most of the weight is placed fore and aft (camera + battery) with very little left and right. So it only makes sense that the pitch and roll PIDs should be different.  I have flown several auto missions lately and some manual flying, all is working great.  However I have yet to try any spline curves, it is on my list though.
MHA, that fixed the zomming, but not the failed connection to APM2 with AC 3.1rc5.
When Copter is connected to APM,
with USB + Battery means you may be doing compassmot. Right now it is not possible to use CLI (Command Line Interface) using Telemetry 3DR radio.
It would be nice if is allowed using 3DR Radio..
I've noticed my compass heading when connected via the USB cable is about 10-15degs different from when I'm powering the APM from a flight pack and connecting via telemetry.  Is this normal?
Very interesting David,
I don't know why it would do this, do you have a log of the tune and the spline flight I can have a look at?
Sorry Raefa, I don't understand what you are saying about ACRO. Could you try to explain this a little more. Also a flash log might help too.
