Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Man this is getting deep and frustrating to find my own posts! And the lack of a topic search is, well, why?  Can we branch off into and RC5/v3.1 version of this?  Just curious.
Good luck Bruce... I will be trying my other board with auto-tune this weekend!! Put it in last night...
I guess I put the shaky one into a plane since the plane FW does not yet do this twitching.
Thanks Detlef and good luck to you .  Let me know how it goes with the autotune! If my new board works, I will put the "wild hud" one in my Bixler 2 and do some aerial photography/FPV - that is if it's not shaky in Arduplane.
You kidding me, hahaha! I just opened the box of a Bixler 1.1... you have the same twitch on your board and now the same plane (more or less). I just loaded yesterday the latest Arduplane in my buggy board and it works on the desk.
Anyway, I let you know if I crash my quad with auto-tune because its probably happening to you then too LOL
I have my fingers crossed for you brother!  You MUST have a successful Autotune flight!  LOL
The 3.1 final release will be in the new forums and be easier to use.  In the meantime if you want to head over now, you can start asking questions about the release candidates and likely get the same support you would here..  http://ardupilot.com/forum/viewforum.php?f=25
OK microseconds makes a lot more sense to me. Let me put my tumbler of high res spiked koolaid down and explain myself... :)
AFAIK the PPM spec allows infinite resolution. It is the Tx+Rx that determine how many steps that 1000-2000us range is broken up into. Most modern tx+rx's are 1024. So they break that range up in to ~1us steps. The exact value depends on end points, trims, etc... you get more steps using 150% end points etc... but 1us/step is doable with a properly setup 1024 tx+rx. Higher end 2048 setups offer ~0.5us steps, and I just learned that some of the newer digital servos offer a rediculous 4096steps. They must use really good pots I guess, and they need 4k radios to reach their full potential. The point is, many users are sending commands to APM in 1us increments, some may be sending in 0.5us increments, and soon they might be sending 0.25us steps to APM.
APM is probably not as precise as a 4096 servo. You mentioned APM has a 1us input resolution? If so, a properly setup 1024 tx+rx is all you need to maximize "stick to APM" resolution; you'd get 500 steps left, 500 steps right. Taking that same setup, and switching DR to 50%, you get 250 steps per side. That may not be a noticeable difference on most rigs. If we hook up a 2048 setup, you can have 500/500 steps with both 100% and 50% DR, because it's limited by APM input resolution... the 2048 setup would be for "pro acro dudes". ;)
OTOH, let's take a 512 res tx+rx setup (the limit of most UHF systems). It starts off with 250 2us steps per side, which is already less than what APM can see. Now cut DR to 50%, and you get only 125steps per side (4uS). IMHO, that is getting well in to territory where most pilots will notice a difference. Besides the extra holding power, higher resolution is why planksters just love upgrading to digital servos... many el cheapo servos have just 4us res, where as digital servos can actually deliver discrete changes per 1us steps.
I understand what you mean regarding centering & dead zone.I picked a bad example. In the context of APM acro, it is the off center movements that count. FWIW, my Atlas digitals have adjustable deadband and range too. I haven't seen the resolution specs for them, but they have programmable travel. I have my pylon racer setup for full 2048 (150% end points), I programmed the servos for just 60* total travel, 1us deadband and I can actually see my surface jump to the next position with every single trim step (yes a single 0.5us step per trim click with 2048, not the JR default if 4x that gives 2us steps per click even with 2048... 8us per click with 1024 :/ ). The mechanical precision those Atlas servos offer is amazing really... I highly recommend trying a set on your next CP heli. There are more expensive servos, but they aren't really any better quality. ;)
is.gdCrunchbase: is.gd is a company (Consumer Web), acquired by Memset.
Not understand. How else should I fly in Acro?
Please see this logs.
And see what with yellow led and battery FailSafe message in flight data screen.
Hi Dean, cheers to all!
Thanks for the info, I'll delve into the documentation wiki.  I'm reverting to 2.9.1 B until this whole enterprise moves out of the beta testing phase.   Too much tinkering, not enough flying and still lots of unexpected excursions, it seems.  I get the e-mail feed but the volume is unmanageable; the signal-to-noise ratio is way too high.
For worry free flying, maybe the arducopter is not the right platform?
Thanks again Dean, Cheers . . . . . . . . Spring
Ning's lack of search sucks, I agree. I found that bookmarking "permalinks" really helps me organize key info. To get a permalink, click the chain icon next to the "Reply by ..." on the top of each post. The permalink will always bring you to the post in question.
LeadWikipedia: Lead is a chemical element in the carbon group with symbol Pb (from plumbum) and atomic number 82.
Hey David,
I think you sent me the wrong log file for the tune. And could you also tell me where you see the oscillations you are talking about in the second log?
Doing two autotunes, one to get close then one to fine tune is a good idea I think. I also got the feeling that a low battery near the end of the tune was effecting pitch a little if I started from defaults.
Hi Springfield,
If you are still on 2.9.1b, take your time. Version 3.X is a whole new level of performance and reliability compared to 2.9.X. So take your time to read the wiki setup pages before you update.
