Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Raefa,
     Normally the yellow led should only come on during autotune or esc calibration.  Is it always on?
     We sent the failsafe status a little different in AC3.1 than in AC3.0.1.  We use a bitmap now instead of sending long strings.  Maybe there's something going wrong there...I'll have a look.
Is the new MP release buggy for anyone else?
I just opened up MP, it asked me if I wanted to update, I clicked yes, it updated (1.2.85), then problems started. It says "Map change failed. try zomming out first." every time I startup now. Connecing to my APM fails now. Most of the time when I hit connect, the LEDs on my APM go out, connection fails, and after I close the timeout dialog the LEDs turn back on. I can still get it to connect by letting connection fail first, then hitting connect again as soon as my APM lights start to flash again. It consistently connects to the terminal (CLI) still, but the GPS test seems to crash.
Looks like the Short is intentional on the compass as it is present on the external unit i got from 3DR also...
Interesting about the pitch and roll PIDs being so different after autotune. I also got similar results, with pitch P at 1.4, and roll P only 0.09. This didn't work out for me at all, it made SplineNav fly a nasty wobbly curve instead of being nice and smooth. So I averaged the autotune pitch and roll PIDs and set them to be the same numbers, i.e. 1.15 for pitch and roll P. Similarly for I and D. After this SplineNav flew a super smooth, precise curve, no more wobbly back and forth.
I wonder if the non-symmetric pitch and roll PIDs would affect the precision of other auto modes as well, since they all use the same loiter controller. But maybe not, since the other auto modes only fly in straight lines anyway. Well, except circle mode, might be interesting to test the non-symmetric PIDs on that too.
Select a map source in the flight planner screen again and restart.
The "Map change failed. try zomming out first." was resolved when I uninstalled the complete thing, deleted the folder in Program Files and reinstalled fresh. The connection problem stays, I get lucky if I hit a couple times the reset button while MP is trying to get a connection but something is not working right. Besides, CLI and firmware uploads always work.
Hi Andre:
Is altitude hold on the APM1 ok?
Regards
tangtl
I am considering ordering a new board.  Maybe the 2.6.  I'm itching to try the autotune. By the way, Is there is a way to enable autotune on rc3?
Hi tangtl,
I havent been able to test ALT_HOLD yet - it's been raining here since the weekend.  Im hoping to test it this weekend if the weather is good...
Yellow led always on. I add logs.
Ok, please see battery FailSafe.
And please what about Acro?
Logs.
Well I just ordered a new 3DR APM 2.6. Hopefully this will work for me.  Oh - also pulled the trigger on an Iris!
