Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Dragu, what DO_SET_ROI parameter you use here?
  • MAV_ROI_NONE = 0: Yaw will hold it's current angle
  • MAV_ROI_WPNEXT = 1: Yaw will point at next WP
  • MAV_ROI_WPINDEX = 2: Yaw will point at the desired WP at the index #
  • MAV_ROI_LOCATION = 3: Yaw will point at the indicated location (The location in the command)
  • MAV_ROI_TARGET = 4: Not implemented
I think that would be a good addition.
and not only for the RTL. It would be good for any way point as well (if not done already).
It would make it very obvious that the copter is reaching the way/home point...
Robert, how would one hack password during a firmware update? It is a wired connection. How would they hack into it?
What am I missing?
Randy during a motor/esc out, can we not give full opposite rudder to stop or reduce the yaw during the recovery?
I always think that when (hope it never will) this happens to me one day, I will give full opposite rudder and try to bring her down while holding the the rudder stick in that position all the time.
Would this not help?
no, is AC3.1 rc3, but is no difference in Circle function
regardless what you configure on Do_Set_ROI, in Mission Planer you should add SET ROI command after each WP.Why? because when next WP is executed, previous Set ROI is overwritten with options you wrote above
Is there a released 3.1 now too? I've been seeing Randy refer to 3.1 but, knew it to be the next pending rolled revision. Yet others posting keep referring to their using 3.1 with revisions (rc1-7) and not 3.0.1 with revs.
So - confusing....
3.1 is not released yet.  RC is short for releade candidate.  I.e rc1 through rc7.  Eventually one of the release candidates will become 3.1
i hope you didn't sign anything about that :) you don't know how difficult is to lift 5Kg safely on a long range fpv trip.
The official release should happen in about a week.  I'm pushing out -rc8 today which is just -rc7 with some minor changes.  I don't think there are any more coding changes that need to be made before the official release, just preparing the wiki and actually one of the major problems is getting a decent video together which uses the APM, PX4 or Pixhawk.
I have some good snippets.  The bits that I want to highlight in the AC3.1 video are:
    1. motors spin when armed
    2. take-off and land in loiter
    3. auto-tune
    4. drift (Jason has provided a video of this)
    5. general loiter and auto performance (I have a loiter in the wind video which partially fills this requirement)
    6. ROI (I have Dragu's video)
Cool! Great timing, I'm on the road and will be home in about a week. Looking forward to running auto-tune on my quad.
