ArduCopter 3.0 is ready for widespread use.  To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner.  The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position.  This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
  • Safety improvements:
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right.  The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3dr frame can be seen in the image below.
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to MarcoDaveC and the rest of the beta testers for putting their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying.  They are excellent!
3DR Quad Set-Up Suggestions        http://www.youtube.com/watch?v=33Tl_rjhQEE
AC 3.0 "Live" Compass Calibration  http://www.youtube.com/watch?v=DmsueBS0J3E
AC 3.0 CompassMot Setup                http://www.youtube.com/watch?v=0vZoPZjqMI4
AC 3.0 Pre-Arm Checks                      http://www.youtube.com/watch?v=gZ3H2eLmStI
AC 3.0 Fence                                         https://www.youtube.com/watch?v=HDnGdo54o-4
AC 3.0 Maiden Flight Checks             http://www.youtube.com/watch?v=NOQPrTdrQJM
I'm confused by your post Jim (Cooper).
Why the rubber grommets on the GPS?  I'm fairly certan that the GPS is not affected by vibration unless it's bad enough to physically damage it, which is more than we'd ever see on these copters.
Certainly isolating the APM from vibration is required, but the GPS module is another story.
Also, what would super simple mode have to do with the GPS locking?What am I missing here?
Bill,
    Super simple mode is like simple mode except that it works even when the copter is behind you.  So for example if you hold the roll stick left the copter would fly a circle around you in a counter-clockwise direction (as long as it's at least 10m away from you).  This require a GPS to work though.
     I've never actually used super-simple mode myself but this is what I think it should do.
that's correct Randy. Ive tried it a few times. Just imagine its attitude always faces outwards from its take of point like lines radiating outwards from the take off point.  Where ever it is around you , front, left, right or behind you, if you pull the pitch leaver down it will fly in to the center back to its take of point
Hi Bill,
I ended up mounting the GPS on rubber grommets primarily to get it off the plate (I didn't have any standoffs handy) and figured the vibration absorption wouldn't hurt.  The super simple mode....I didn't know if maybe it hadn't been tested and may have been causing some weird control issues.  Not too many people use simple or super simple (I don't think) so eliminating some of the variables just seemed to make sense.  Hope I have addressed your confusion..  Thanks for the feedback.  Jim
Got it.  Thanks Jim.
I was certainly aware that GPS lock was needed for simple and super simple modes, but I couldn't see how switching to those modes would unlock the GPS.  I guess if there was a bug, it could cause issues with the GPS code in the APM as you mentioned.  Doesn't sound like this is an issue though.
I am quite sure it is not an issue - more likely either I did a bad compass calibration and/or vibration.  Seems to work ok now.
I just updated to 3.0.1 and after update, I am not able to connect anymore to the APM and see my params.
I however can connect with terminal and see that 3.0.1 is loaded. I reverted back to 2.9.1b and seems to work...
Any clue what's happening here?
This is the old thread, next time could you post over here?  Basically though I think you should go to the terminal window, then type "setup", "reset", "Y" and then redo your config (sorry!) and it'll be ok.
I have one question:
If I've FS_GPS enabled, when I arm the copter (indoor, with no GPS fix) at the beginning the motors run and 0,1 sec later its stop. If I've FS_GPS disabled this doesn't occur.
This could be a bug? How can I fix this?
Thank you so much!
Hello,
I have three AP;  one 2.0, another one 2.5 both are from 3DR  for my aeroplane and copters and one 2.5 from chine that I used to run some tests
Two month ago I burn the 3,3 regulator of the chine one I read the topic with the procedure to change it.
When I was in the investigation process to find a solution I think that somebody had written that if you installed de 3.0 release in a chine AP board you could burn the 3.3 regulator.
I have my test chine board again alive and I have installed 2.9.1 release and is working with no problem in a small test quad. , but I would like to installed the 3.0 or 3.1 firmware.
I would like to know if somebody else has read what I think I read please let me know if I am right or wrong
Can  I  update this board with 3.0 firmware?
I am looking forward to hearing from you guys any comments.
Thank in advance, Leopoldo
Did you end up with the s800?
