Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
I can't find motor test in MP.
"Individual motor tests (see MP's Initial Setup > Optional Hardware > Motor Test)"
the only option available is "Compass/Motor Calib"
Randy, Thank you for update
 Tomorrow, If i have free time. I maybe have test it.
Congrats.
Thanks Marco.
...charging my lipo's now!
...testing list now ready.
...let's fly!
great news...so many options...
Downloaded new 3.2 fw
Done very basic tests (Stabilize-AltHold) on my quadcopter... no dramas up to now!
...I'm struggling with CLI functions no more available ...I can't find compassmot, reset, erase, enable/disable logs, etc on MP...is there a doc that describes where we can find these functions?
Thanks to dev team for this new release that looks really interesting!
Luciano
Hi Randy, congratz to a big progress with EKF, it's getting better and better!
BTW, I'm using a PX4, will it also receive the same features as Pixhawk?
OK cool, new features to always improve Arducopter, thanks diydrones community :)
What about parachute support? There's possible to know how does it works in detail? algorithm (vertical speed, gravity, roll angle threshold values) for auto eject and driving capability (servo, relay)?
Also on 3.1 post Marco talk about pause features during auto missions, I don't see anything regarding this interesting feature....
will fly on Wednesday with 3.2. will leave a feedback. it is getting ever more interesting. the reliability of hardware (pixhawk) and firmware 3.0+ is very high now. i really never had issues while flying (a misbehavior). whatever they were only because of wrong params settings. the mission now resumes after any manual command interruption in auto was needed. i want to fly downhill. can i give negative altitudes while maintaining a fixed height above the terrain. the mission planner does not takes negative altitudes. anyway the wait for 3.2 was as exciting as going on foreign holiday trip. hats off to devp team.
Hello
Thanks to the development team.
tested with Pixhawk Qud in strong winds up to 45 kmh.
Stabilize is OK, very stable
Loiter is much better and more accurate
Rtl very accurate
Hybried is OK could be a bit stronger, setting a bit higher.
EKF
is excellent in the strong wind. in Loiter, althold, Rtl.
Mission Planner .... 30 673
Spline not exist.
Chute parameters does not exist
will continue to test the other functions with better weather
Giuseppe,
     The method that's implemented in the mission planner only spins the motors at a low level (13% i think) for a short time.  The arducopter side is very simple though and it does allow the ground station to spin the motor at whatever speed it wants for as long as it wants so it's really up to the ground station developers.  The mission planner issues list is here.  I can't comment on when MichaelO would get to the request of course, that's up to him.
Thanks Rainer for your detailed report.
Jay,
     It should be there but perhaps it's only the Beta version of the mission planner or maybe only in the  "Advanced View".  Both those options can be selected by going to Config/Tuning > Planner and check the "Beta Updates" and/or "Advanced View" checkbox.
