Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Yes Luciano, some functions are removed from CLI due empty space for the other new features.
Some are now available in the Planner, out from CLI.
Another improvement, not reported by Randy in the main post is this one:
- added new mode for CH7/CH8 (auto mission reset and pause mission)
Rainer,
     Spline can be used by setting the mission command to SPLINE_WAYPOINT.  If this doesn't appear in the list of available commands it probably needs you need the "Advanced View" or "Beta" version of the mission planner.
      Spline waypoints take all the same arguments as regular waypoint.  We will have to put up some documentation on how spline waypoints work but the short form is that you can mix and match regular waypoints and spline waypoint commands and the mission planner will show you what the patch will look like (although there are some bugs in the path the mission planner comes up with).
Randy,
Where can i find some info about the new compass calibration process with the globe figure?
i searched and couldnt find anything.
Emile (VRBrain team) has found a bug in AC3.2-rc1.  The loiter and auto update rates are running too fast on the APM2 and too slow on the Pixhawk.
I suspect it's not too dangerous as the APM2 will probably simply run at the fastest speed it can which may make telemetry very slow.  For the PX4/Pixhawk/VRBrain it will likely lead to a pulsing throttle during missions which is annoying but not dangerous.
..I won't push out a fix tonight because it's too late here.  We may push out a fix tomorrow although I'd prefer to wait until Fri so that we get into a rhythm of one release candidate per week.
Updated Mission Planner to last version and found new compassmot function and setting for logs in standard mavlink screen (no CLI). For erase/reset I understand that we must wait for new MP version...but it is not a big problem. Great!
Flew our 550 hexa this afternoon with this 3.2 beta firmware before I read this. Noticed that it flew better than before. Is it because of the onion feature? What does onion actually do? Does it make the multi fly smoother?
the CLI still here by the way.
So many things in 3.2 that I've been so eager for!! I'm so pumped to get in the air with 3.2.  Too bad I turned my quad into a smoking hole in the ground on Friday.  (https://www.youtube.com/watch?v=6BGHvz1Owe0).  My rebuild will be fresh with 3.2 I guess.
thanks Randy
spline is OK, have not been suspected in the waypoints.
but where are the commands of parachute
Congrats on the first release candidate. I don't think there is ever enough thanks that is given to all those that contribute to the code. For that I have nothing other to say right now then THANKS!
I will get 3.2 loaded up on my disco and do some testing.
Loaded 3.2 rc1 on my Steadydrone Q4ad V style frame with APM 2.6 and 3DR GPS.
First thing i noticed  was that the my pids where off. It needed a bump up  on several pid settings. After some manual tuning it flies just fine in stabilize mode. It's getting rainy now so i will resume testing tomorrow. First alt-hold then loiter and then hybrid mode. I am curious about hybrid mode and how it compares to DJI GPS mode.
Anyone tried hybrid already? What are your impressions?
