Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Is SBus RSSI input 0-5v working with 3.2 and the pixhawk?
Here are the logs, I rolled back to 3.1.4 to get them, then went up to 3.2 rc1 and I am getting the exact same as above.
Anyhow I got the logs, back to the initial issue, changed to GPS mode and it flew away from me,
here's my flight log #1
here's my flight log #2
here's my flight log #3
Edgar, go to the first page of this thread and Randy has posted how to get them from the flight data screen.
Great addition!
Thanks, got it, works great, I attached that log from 3.2 rc1 download but I assume its the same.
HDOP was okay
You can also see where it took off when I changed to mode 16 (Hybrid)
here's my flight log #4
The Roll/Pitch problem came when Hybrid engaged Loiter (when DPosX/Y are updated).
We can see here the Copter rolls away its target position instead of maintaining it.
You had no stick Input and the GPS was great so, maybe, check a compass issue.
If the copter thinks he's goind to North but actually flies to South, that could, imo, bring that kind of behaviour.
Please give another try to hybrid and also Loiter.
Check as well your param values.
Hi Randy,
I noticed there's an EV = 28 in my log which was not define ardupilotwiki.
