Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
What is your TX/RX system?
FrSky
That's what i got and I have the same problem.
I tested the 3.2-rc1 firmware today, on an APM 2.6 equipped 600mm span quad, running FrSky PPM Sum receiver.
I flew a handling test in Stab and Loiter, then did an Auto flight through four waypoints, two of which were 'splines'.
After much flying recently on 3.1.2, release 3.2-rc1 felt very fast on roll and pitch response, but sluggish on yaw.
The pitch & roll response felt more like my Trex-500 clone actually. I could like it, but will probably reduce the rc_feel_roll_pitch parameter, and increase whatever will speed up yaw response. I don't need the quad to feel like a 3D heli :)
The Auto waypoint flight flew the mission OK, but heading out to the first waypoint the quad did some fast pitch bumps, about three in a row half way out. It flew the next two splines ok, perhaps with a couple of pitch bumps again (hard to tell at the distance away). It did a two rotation loiter circle at the last waypoint, but the circle seems to be half the diameter I expected (2x radius).
So apart from a slow yaw response (accel and decel) and some pitching irregularities it's OK so far.
Log attached.
mr.sneezy
@Pierre, it seems,  from the log, that you lost GPS connection during RTL.  Your Nsats dropped to zero in the middle of RTL and your ThrIn went idle upon RTL....that's why it fell like a rock  - just an observation.
Thanks for looking Willy.
Actually it starts falling at line 8850 and hit the ground at line 9000, I had all the 9 sats during the crash. It's only in the wheat field that it has lost satellites.
We already discuss the idle ThrIn with Pedals2Paddles, it should not be as problem at RTL is supposed to control it. I am more concern about the ThrOut that was also at zero during RTL !
So in local discussion the following question came up: Given a "normal" size Pixhawk quad presently running decently under 3.1.x. how much risk would be involved in going now to 3.2 rcX Beta IF it is flown by a pilot capable of manual flight, and IF it is flown only in stabilize, alt-hold and loiter modes, and only in mild to moderate fashion?
I ask because if this is reasonably safe I'd rather be fine-tuning for precision on 3.2 than be essentially wasting time fine-tuning 3.1X while waiting for a general release of 3.2. My thinking is that perhaps any potentially fatal sorts of issues with these most basic flight modes would necessarily be addressed early on, and if that's correct I have no problem simply not using modes or features that might still be shaky. As opposed to waiting a longer time while problems with advanced features are being sorted out.
I would still provide feedback as appropriate, and maybe it would be useful to eventually have feedback for advanced features coming from a platform known to have particularly well dialed in basics.
Fairly much where I'm coming from. My thoughts are that guys that can fly well enough to cope with an odd control loss should push the boundaries a little to benefit development for the guys that can't...
Martin
Hi Oliver,
The 3.s is a beta so expect issue but enjoy new functionalities cq flight modes, don't use the first rc candidates on your multi million machines.
@Randy,
When can we see 3.2 rc1 online again in MP?
Try increasing ATC_ACCEL_Y_MAX  . This is a new param in 3.2.
I had to bump it to at least 50000 to have something decent.
anyone tried a FLIP on AC3.1.5 rc1.
I'd be more than happy to do that with an inexpensive stripped-down quad (and have done so in the past) but at the moment all my eggs are in one basket that has a lot of expensive components and a lot of build time.
