Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
could you share you ublox txt?
Jörgen, the GPS I mentioned with 5 sats was a NEO6M. I also use LEA6H and it has 8-9sats in cloudy conditions.
Thomas, I'm aware of that effect with the sats on the horizon, so my workaround is to shield the antenna a bit with a plastic yoghurt pot. So you can filter them out. I know it's strange to force a reduction of sats, but that works well on my copters.
Winston, these sats could be the reason. I recognized, when such a sat is captured the position of my quad jumps around 2m away.. yesterday it happened when sat #16 intermittently occured.
Yudi, yes at CSGshop.
Devis, yes can do it asap.
Titeuf, it runs with factory settings, config will be send on startup from pixhawk, so I didn't change.
@christian, so what i understand is Ublox-Neo-M8N is plug and play with pixhawk. all one has to do is connect GPS and compass (i2c) connectors. is that correct?
Hi all,
Ravi yes it's PnP so here is a pic of the wiring and an unbelievable new satcount :-)
red(+), blk(-), grn(compass(SCL)), yel(compass(SDA)), blk(GPS(RX)), blk(GPS(TX))
I separated the GPS wires, so you can see how they fit in the pixhawk plug..
that is awesome :). where did you grab the  Ublox-Neo-M8N?
edit: woops read up, i see it now  http://www.csgshop.com/product.php?id_product=173
ordered one - I have to try it out :)
hopefully the sats have a good navigation controller to avoid hitting each other...
Many thanks chris...I will order one
How about apm counfiguration? Could you tell me the wiring for apm? Thanks
Christian! Another problem that I noticed is, a random flashing in the reception of the satellites, suddenly the satellites do not appear in Mission Planner and in less than a second, reappear again.
so,will you use two gps?
@Ravi,
I do not believe that the default uBlox M8 configuration file is the best for operation with the Pixhawk.
Here is a recommended configuration modification to work with the Pixhawk for Europe:
PRT (ports)
UART 1
Protocol out
UBX
Baudrate
38400
RATE (Rates)
Measurement Period
200 ms
Measurement Frequency
5 Hz
NAV5 (Navigation 5)
Dynamic Model
Airborn 4G
Fix Mode
3 - Auto 2D/3D
Min SV Elevation
10 Grad
DGPS Timeout
120 sec
SBAS
Subsystem
Enabled
PRN Codes
EGNOS (EUROPE)
120, 124, 126, 131
TCIII ArduRover2 Developer
