Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
that is awesome :). where did you grab the  Ublox-Neo-M8N?
edit: woops read up, i see it now  http://www.csgshop.com/product.php?id_product=173
ordered one - I have to try it out :)
hopefully the sats have a good navigation controller to avoid hitting each other...
Many thanks chris...I will order one
How about apm counfiguration? Could you tell me the wiring for apm? Thanks
Christian! Another problem that I noticed is, a random flashing in the reception of the satellites, suddenly the satellites do not appear in Mission Planner and in less than a second, reappear again.
so,will you use two gps?
@Ravi,
I do not believe that the default uBlox M8 configuration file is the best for operation with the Pixhawk.
Here is a recommended configuration modification to work with the Pixhawk for Europe:
PRT (ports)
UART 1
Protocol out
UBX
Baudrate
38400
RATE (Rates)
Measurement Period
200 ms
Measurement Frequency
5 Hz
NAV5 (Navigation 5)
Dynamic Model
Airborn 4G
Fix Mode
3 - Auto 2D/3D
Min SV Elevation
10 Grad
DGPS Timeout
120 sec
SBAS
Subsystem
Enabled
PRN Codes
EGNOS (EUROPE)
120, 124, 126, 131
TCIII ArduRover2 Developer
@Christian,
I am presently operating a uBlox M8Q (active antenna) inside my home in southern Florida (USA) and the GPS has acquired 11 - 12 sats with an HDOP of between 0.7 - 0.9.
I expect the GPS to do much better outside on my rover.
If you are inside the HDOP at best is bogus. You have all sort of multipathing issues which are undetected, just that your reported position will be incorrect. I often see HDOP <2 in my basement, but the plot of the location is all around the house.
And then sometimes I see this
There is no 'error' reported, just that the position is moving, in this case SW. The GPS is still in my basement. HDOP looks fine. HDOP is only indicative of accuracy, but in built up areas, or indoors the gps can be fooled into believing it is somewhere when it is somewhere else. Only with a clear view of the sky can you be sure you have a quality lock.
The more accurate the timing of signals the better, but it's an inherent weakness that can only resolved with a technological innovation. (ie. walls that don't reflect GHz signals ;) )
yudi, I will try APM at the weekend.
See DF-13 shematic for APM:
compass cable is the same and goes to I2C port.
Winston, did you connect via USB or telemetry? Sometimes I have a telemetry lag causing the numbers to disappear.
So we have to check the GPS in CLI while connected via USB. (with 3.1.5 bcs 3.2 doesn't have CLI)
If there appear lines like '.................................................' we really have a lag in GPS communication.
