Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Tags:
@Christian,
I am presently operating a uBlox M8Q (active antenna) inside my home in southern Florida (USA) and the GPS has acquired 11 - 12 sats with an HDOP of between 0.7 - 0.9.
I expect the GPS to do much better outside on my rover.
TCIII ArduRover2 Developer
If you are inside the HDOP at best is bogus. You have all sort of multipathing issues which are undetected, just that your reported position will be incorrect. I often see HDOP <2 in my basement, but the plot of the location is all around the house.
And then sometimes I see this
There is no 'error' reported, just that the position is moving, in this case SW. The GPS is still in my basement. HDOP looks fine. HDOP is only indicative of accuracy, but in built up areas, or indoors the gps can be fooled into believing it is somewhere when it is somewhere else. Only with a clear view of the sky can you be sure you have a quality lock.
The more accurate the timing of signals the better, but it's an inherent weakness that can only resolved with a technological innovation. (ie. walls that don't reflect GHz signals ;) )
Winston, did you connect via USB or telemetry? Sometimes I have a telemetry lag causing the numbers to disappear.
So we have to check the GPS in CLI while connected via USB. (with 3.1.5 bcs 3.2 doesn't have CLI)
If there appear lines like '.................................................' we really have a lag in GPS communication.
Emin,
yes I'll give it a try. It's a pitty that Missionplanner can't display both GPS data yet. I'm courios of what will happen.
Bill, you're right. So my solution is to shield the GPS antenna directly from "low elevation sats" and multipath signals. Remember my yoghurt pot trick.
Thomas, thank you for the ublox config, but..
As a every year discussion I don't agree with enabling the signal correction via SBAS. In my opinion that makes sense for 24/7 applications or those who need high absolute position accuracy. For our copters, who fly around 30min, it could lead to damage due to GPS glitches.
So I think we only need "relative position accuracy" where a bit off is accepted. I don't need to drop things on a 20cm target.
Randy told us, the ublox config is being sent to GPS on each boot. Is this still the case? Does this config overide the SBAS settings? Sorry I didn't have had time to investigate whats going on during boot.
Seems to depend on location. If its not turned off, I did not experience any bad habit because of activated SBAS (EGNOS ..3 Channels)@ center of Germany . (Max M8Q with small active patch) I additionally disabled QZSS @ GNSS Config.
@Emin: Peter showed a direct log comparision at drones-discuss between Max M8Q and LEA 6H as well between Max M8Q and NEO M8N, quite impressive.
thanx for posting very clear pictures for connecting NEO-M8N to pixhawk. that would be a great help. i think configuration for the Neo-M8N has to be through a configuration utility (if config is needed). have to get it ASAP.
Hello,
Hopefully someone can help with a log-download issue. I have been testing 3.2rc on 2 pixhawks without issue; flyes great and logs are downloaded easily through USB.
I then loaded 3.2rc2 on an APM, and it has become impossible to get the logs off the flight controller. I try to download over mavlink, but no matter what I end up with the attached error. I see it start to download, but then it fails:
Any idea what I should be doing differently? do i need to change any telemetry radio settings to make this work?
Thanks!
Raph
P.S. I tried to first post on the ardupilot forums but although Stefan tried to help, no solution has yet been found.
@Winston,
I believe that there may be a problem with the capability of the CSG M8Q to handle a Measurement Period of 200ms (5Hz).
I too have seen the data stream glitches, when using U-Center, at a Measurement Frequency of 5Hz.
Switching back to a Measurement Frequency of 1Hz (default) cured the data stream glitching.
Also, the HDOP value appears to be stuck at 1.1 no matter how many sats are presently be acquired.
PS: It appears that U-Center does not decode the number of sats and the HDOP when in the UBX (binary) mode.
Christian,
Yes, the config is being sent to the ublox on each boot. It doesn't send everything though and I had a look in the AP_GPS_UBLOX.cpp file to see what exactly it's sending but even for me that would take a bit of a review. It also tries to turn off messages that it doesn't recognise.
45 members
1472 members
282 members
470 members
57 members
Powered by
