Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
True: The u-blox 7 engine (chip) itself features more, even Galileo, which doesn´t exist yet ;-)
But : According to the pics, this Hobbyking board comes with a 1575MHz (GPS only) patch, same family DJI is using for the NAZA, btw..
... but you can buy the dual band antenna from Digikey and put it on the HK board and have an enclosure. It's 10 cm larger but it looks like it might fit in.
http://www.digikey.ca/product-detail/en/CGGP.35.3.A.02/931-1153-ND/...
thanx terry, that was something i did not think about before ordering ublox 7 form hobbyking. i will try to upgrade it using sparkfun antenna.
When i use the pixhawk testing 3.2rc2 i found two bug
1.Running 3.2rc2 without any peripherals, just use usb connect pixhawk.than pixhawk running good and leds hand yellow double flash.But after a period of time,leds stop flash and FMU froze.If i connect full of peripherals(Safe key,GPS,Power module),it just running gread,and never froze again.
2.When the Channel 7 or 8 choose AutoTune, and then use the mission planner do radio calibration pixhawk froze.
sorry my English is not so well, all those use google translation.
Does the sparkfun antenna receive the higher frequency GLONASS?
@terry, i meant the digikey antenna. sparkfun was written inadvertently.
Hi
here is comparison of LEA6(red) and M8N(blue) (behind the house)
LEA6 setting: GPS_TYPE=2(ublox); connected to GPS port; factory settings overided by pixhawk boot
M8N setting: GPS_TYPE2=2(ublox); connected to Serial4/5; didn't check if overided, but elevation set to 10°, SBAS off
Raph I got the same error during log download over mavlink.
Wow there are so many Mavlink Bad Packet (crc fail) messages in debug console... now I know why connecting via mavlink is sow slow since I use a pixhawk. APM has no problems. Fast connection as usual. My SiK firmware is 1.6.
Marco had same issue some weeks ago:
http://youtu.be/ZrihdM0txdw
Somebody said:
"If you untick ECC on both modules that should solve the issue.."
So I'm going to test that tomorrow.. Hopefully this is not caused by serialport or gps settings.
Ravi,
I'm very interested in you results, with stock- and CGGP.35.3.A.02 antenna. That price is unbelievable.
hi,
1. I've only seen pixhawk freezes when GPS or other UART(Rx/Tx) devices were connected in reverse(Tx/Rx). So I can't imagine the reason, perhaps it could hang if an auto detection routine went into time-out if nothing was detected.
2. maybe you reversed RC-in and SBUS input? It would be great if you could upload a picture of your wiring.
So if you like football, 3.2 can do the ball game too, otherwise trimming the hedge :-)
Randy, did you investigate that glitch behaviour happened in your youtube video?
wow ... amazing. I am assuming HDOPs also followed that trend.
So just to be sure, you used the M8N from csgshop with "stock" GPS+glonass antenna?
I wonder how the M7N will compare to the M8N with upgraded GLONAss antenna, in the US ...
