Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Does the sparkfun antenna receive the higher frequency GLONASS?
@terry, i meant the digikey antenna. sparkfun was written inadvertently.
Hi
here is comparison of LEA6(red) and M8N(blue) (behind the house)
LEA6 setting: GPS_TYPE=2(ublox); connected to GPS port; factory settings overided by pixhawk boot
M8N setting: GPS_TYPE2=2(ublox); connected to Serial4/5; didn't check if overided, but elevation set to 10°, SBAS off
Raph I got the same error during log download over mavlink.
Wow there are so many Mavlink Bad Packet (crc fail) messages in debug console... now I know why connecting via mavlink is sow slow since I use a pixhawk. APM has no problems. Fast connection as usual. My SiK firmware is 1.6.
Marco had same issue some weeks ago:
http://youtu.be/ZrihdM0txdw
Somebody said:
"If you untick ECC on both modules that should solve the issue.."
So I'm going to test that tomorrow.. Hopefully this is not caused by serialport or gps settings.
Ravi,
I'm very interested in you results, with stock- and CGGP.35.3.A.02 antenna. That price is unbelievable.
hi,
1. I've only seen pixhawk freezes when GPS or other UART(Rx/Tx) devices were connected in reverse(Tx/Rx). So I can't imagine the reason, perhaps it could hang if an auto detection routine went into time-out if nothing was detected.
2. maybe you reversed RC-in and SBUS input? It would be great if you could upload a picture of your wiring.
So if you like football, 3.2 can do the ball game too, otherwise trimming the hedge :-)
Randy, did you investigate that glitch behaviour happened in your youtube video?
wow ... amazing. I am assuming HDOPs also followed that trend.
So just to be sure, you used the M8N from csgshop with "stock" GPS+glonass antenna?
I wonder how the M7N will compare to the M8N with upgraded GLONAss antenna, in the US ...
sorry forgot hdop. yes stock antenna from csg.
LEA6(red) and M8N(green)
Outstanding ...
Thanks for posting these logs.
Test report on AC 3.2-rc2:  I did several auto mission flights today.  a) first flight - auto take off to 30 meters then proceeded to spline waypoint #1 at 30 meters altitude and continue until all spline waypoints were completed and land.  The flight was very smooth and perfect - successful test! b) second flight - auto take off to 10 meters then climb to 30 meters at Waypoint #1...the copter was slightly bouncing up and down with pulsating throttle until it reaches 30 meters and flew smoothly to the next spline waypoints and continue up to the last spline waypoint. Again, while descending it slightly bounced up and down with pulsating throttle.  Please see attached log at CTUN. c) two more flights - but, this time all take off and landing altitudes are the same as the spline waypoints altitudes....no bouncing, no pulsating throttle....perfect flight.
Willy could it have something to do with Warning#2 on top?
