Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Update Mavlink bad packets:
unchecking ECC box on both modules did the job!! Now the wireless connection is outstanding!
thanks for the update! that is a bit disheartening though.. ECC is recommended in the documentation - correct?
https://code.google.com/p/ardupilot-mega/wiki/3DRadio?wl=en
yes it's recommended..
I also noticed a high frequency blinking of the red LED of Pixhawk telemetry. There was no connection established to PC. That means something sends a lot of data into space. I'm not sure if that happened with 3.1.5. but it didn't with APM.
There should only be heartbeat blinking..
Hi Christian, Thanks.  i really don't know because warning #2 says "if two spline waypoints are created one on top of the other". In my case, the waypoints are far from each other. Anyway, they might be related and hopefully fixed in rc3.
I also noticed faster connection of the copter to Andropilot(Android tablet) with ECC disabled.
I agree. Unfortunately my PixHawk won't work with anything earlier than 3.2. It freezes up with any copter versions of 3.1.x so I'm anxiously waiting for 3.2 to be released. Until then I'm stuck doing short test flights.
Is there any schedule or estimated date for 3.2 to be released? When is RC3 coming? :)
This is meant to be an encouragement, not a complaint! ;)
My PixHawk works fine with 3.1.5 as long as I don't use waypoints with 0 Lat and 0 Lon. I don't think your freezing is a 3.1.5 problem.
Raph, i tried today checking the ECC box but increasing the air speed to 128. it works! Log download is easy and also the wireless connection.
Willy thanks so much - i will be making this change soon. I'm always hesitant since i have to change the setting on a bunch of telem radios.
thx willy, so you doubled the speed which was halved by ECC.
So now its the only question, in which of the 2 cases the range is not badly decreased...
Will try flying with a) ECC untick,airspeed at 64 and b)enable ECC,airspeed at 128 then compare the range.
