Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Chandruth, Euan,
It's actually not a hard-coded 25% but rather it's 1/2 the THR_MID value (which is by default 500 = 50% of throttle).  This is also the maximum throttle level used to provide feedback to the pilot as the throttle is raised (but before the vehicle takes off) in AltHold, Loiter, PosHold.
This means that for copter's like Euan's, setting the THR_MID parameter is quite important.  For these copters, if the pilot ever wanted to transition back to stabilize it would be quite important to get that right anyway.
So the problem with making the level lower is that we don't allow the throttle to get lower than a value that would affect attitude control.  We haven't set a specific minimum but instead we set a flag each time the "stability patch" (aka the motor mixer) reports that it couldn't achieve the low throttle requested because it would mean sacrificing roll, pitch or yaw control.  Whenever the autopilot (i.e. Alt Hold controller) sees that flag set it stops reducing the throttle.  Overall this means the throttle doesn't drop far below what it needs to to land... so it will never get down to 5%.
Leonard and I have discussed enhancing the AltHold / landing controller so that it does allow the throttle to get lower by giving up on attitude control slowly.  This would also help landing on slopes.  It's a little tricky though so we haven't done it yet.
What does one do if the inner compass checks fail due to high offsets [ - 150 isn ] ? Aluminum foil? Something like this? Is aluminum the best shield? I see This so it makes me think aluminum is one option. I do not want to fly with checks off again at least so when the fail over is resolved the inner is ready to be an option. I have a new pixhawk on the way gonna try a few things but if you or anybody had thoughts on things to try I'd sure like to know! First thing I am going to try is setting the pixhawk on a 4mm or so flat piece of aluminum. Then maybe paint the battery cover with that EMI/RFI paint mentioned above. I'll report if I see any improvement. That would be fantastic if that paint worked. Light weight and would easily work on all set ups. ps I did post this in another thread and got zero response. I try that at least I know this thread can get WAY off topic.
Richard,
Ok, thanks for the report.  I'm going to increase the allowance to maybe 200 or 250 for the Pixhawk.  I think the 150 limit was reasonable for the APM but I think the overall mag field length is longer on the Pixhawk so slightly longer should be ok.
Hi Randy,
If its the stability patch that doesn't go down to 5%, how about using the RC transmitter PWM values from throttle input. Use 0%-5% of calibrated RC Throttle PWM. This should be separate from the Desired Throttle to the motor mixer right?
Regards
Chandruth
Chandruth,
Yes, we could do that.  There are a few reasons we haven't done that:
1. we need to reliably determine if it's landed in all modes and we can't rely on the pilot's throttle during Auto, Guided or throttle failsafe situations.
2. sprung throttles are becoming more common and I wonder if it's reasonable to expect people to pull the throttle all the way down once the vehicle has landed or should they be able to hold the throttle 1/2 way down and have it slow the motors?
3. we're not getting false positives with the current check and we didn't have this requirement in AC3.1.5 which people seem ok with.
So, definitely not saying 'no'... just saying 'haven't done it yet' and it's unclear if it's necessary.
You've got me thinking a bit more about this ...above I said this:
.. but now that we have a two-stage landing process we could make an exception so the autopilot does keep reducing the throttle if it thinks we've landed.  We could then reduce the overall-throttle requirement for the 2nd stage of the landing detector (which is the more critical stage).
By the way, 25% sounds high perhaps but remember the THR_MIN for most copters is 13%.  That 25% includes the deadband at the bottom of the ESCs.
I'm a bit reluctant to make any further changes to AC3.2 unless they're absolutely required but I'll think about this a bit more..
Is that only relevant for Pixhawk Users ?
On APM 2.5 i can just update to rc10 ?
One unfortunate thing is that we found an issue with the Compass device ids and this will mean that a number of people need to go in and do their compass calibration again.  I'm really sorry about this.  If you know your compass offsets are ok, you can get around having to redo the calibration by going into the full parameters list and:
     a) write down the COMPASS_DEVID and COMPASS_DEVID2 numbers that you see
     b) increase the numbers by 1 and press "Write Params"
     c) return the numbers to their originals and press "Write Params"
     d) reboot the board.
Christian,
Yes, sorry, forgot to mention that only Pixhawk users (or VRBrain users) might be forced to re-calibrate their compasses (or they may choose to override the need to recalibrate by following the instructions you've quoted).
Hi Randy,
Take your time with it. If it comes to point there can always be a 3.2.1. Releasing 3.2 takes priority. Just thought a RC throttle 0%-5% check might remedy what users of X Aircraft flight controllers were facing. I was looking at it in a RC stick position percentage rather than overall throttle. Regarding the spring throttle, even those you have to lower to idle for a second or two to complete the landing. I think with those larger 30 inch prop quadcopters on 12S, THR_MIN will surely go below 13% due to the Power to Weight aspect of it. As for the second level of the landing check, in the case of a false positive and throttle starts reducing, is the pilot still able to throttle back up to safety? Anyway no rush for this if the current landing detector works well enough.
Regards
Chandruth
when in loiter or poshold mode, what parameter to change if i want make copter ascending too fast.? like old poshold.
Hey!
After some problems, I reconfigured my mag (rotation roll180 > none) and recalibrate it. Also I bought a new GPS (uBlox NEO-M8N) because my gps data are not really good. Today I start the next flighttests. But they are really bad. :-( First time, the led switches between blue/yellow. After a few minutes I've get a stable green signal... I think it tilt a little bit to one side, I start with more throttle and control to other side... The stabilize mode was ok. Then I change to stabilize super-simpel and it seems the control are inverted - back to stablize... At last flight the copter tilt to right side and grounded (1-2m). Only one prop was broken.
I haven't any idea what's wrong. Could the pixhawk-hardware (sensors) have an error? The log is as attachement: 8.BIN
Configuration: X8, Pixhawk 2.4, AC 3.2-rc9, HMC5983, Drotek uBlox NEO-M8N, AttoPilot 90A, SimonK-F30A, MN3110-26 (470KV) with 15x5.5
Thanks for that. I'll have to play around with the trims a bit and see what I can come up with. That could be the case. I sort of assumed that it wasn't a trim issue because if I'm in loiter, typically it will stay put, so wouldn't that tell me that I have the trims zeroed? Not sure...
