Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Copter shot straight up full throttle while it alt hold I immediately hit stab to come back down. 3.2 rc 14. never had this in rc10 only thing changed other than rc 14 that I can think of is new esc's. Love 3.2 butter smooth until now. If anybody could look at the log I would appreciate it.
Climbing in Alt hold is a common symptom of excessive vibration.  The auto analysis quickly confirms that is the case with this log.    Perhaps you have something hitting the autopilot.
Log File C:/Users/Navigator/AppData/Local/Temp/tmpDD1E.tmp.log
Size (kb) 9632.8583984375
No of lines 132504
Duration 5 days, 14:45:06
Vehicletype ArduCopter
Firmware Version V3.2
Firmware Hash c8e0f3e1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (57.72%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: GPS
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = WARN - Check vibration or accelerometer calibration. (Mismatch: 1.42, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
Please start with the auto analysis tools first as it can save everyone a lot of time.
Also please review the log yourself and look at the DAlt and the Baro Alt and you can see the effects of the vibration on the vehicle
http://copter.ardupilot.com/wiki/downloading-and-analyzing-data-log...
Also look at accelerometer X & Y values.  There is a pretty big offset between the x & y accelerometers.  Did you bang or move the autopilot?
I only recently got the PC version of Mission planner I've been using the Mac version APM Planner which doesn't have that auto analyzer.  So I will for sure try that out. Not sure why it says zero sats it was over 7. I don't like that compass issue either. It's a 3dr compass / gps on a mast so not sure what more I can do with that. I recalibrated twice.   I know what you mean about vibration but I'd be surprised if it was that. I've had that before and it's a constant thing and the copter kind of just doesn't hold alt very well. This holds alt perfect! No issues then it's like flicking a switch it shoots up. Did the same thing here  [ see new log ] but not as bad. Not saying your wrong just I'd be surprised if vibration acted that fast and so abrupt when it was perfect otherwise. Thanks for the help though!! I'm sure it's a set up issue one way or the other. I did re-secure the pixhawk when I did the esc's maybe it's loose or bumping something.
You can also upload your files to Droneshare and the auto Analysis tool is available right there.
But you don't need to use the auto analyser either.  You can graph all of these functions in AP2
Also, the GPS status and Mag status are not related to the climb in this flight.
If you re-secured the autopilot then you need to re-do your accelerometer calibration.
Thanks Caig I will try drone share. Did not know I could graph the vibration in AP2. Which is the vibration I need to look at? still learning about logs / analysis ...I appreciate the insights.
Here you have usefull information, I was working on same issue last week with great results http://diydrones.com/forum/topics/vibration-isolation-and-dampening...
Thanks Cala  I completely agree with the frame being solid is the main factor aside from balanced props! Lots of good info in there thank you
I have a hexacopter I have make an so many RTL'S with the altitude of 5 in the flight plan it done perfectly when iam setting into the auto mission its not getting the required altitude which was 5 default alt . I have reinstalled mission planner no use my hexa configuration is apm 2.6 3.1.5 ac firmware with the 3dr gps I dont understand what is the problem and what is the bug in the firmare or any other. ..help me out......
thanks in advance
yuvraj
Hi There,
i'm just turning in circles, i've still problem's with the new Autotune. I onestly don't understand why it was changed since AC3.1.5 as it was working like charme. I already suggested to make it adjustable for those how want to get out the last from their frame and Hardware. Basically if the PID's are too high and it start oscilating there is more to lose as to win.
I have my new iris+ and also my hexa suffering and there both like new no hardware issue.
here is comparision between Auto tune on the left and Iris Factory settings on the right
Autotune is going nearby to be double factory settings
Will 3.2 be beta forever?
Greetz Chris
