Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Will be getting that to you. Not using spline points
I believe this has been touched upon but to reconfirm.
We are seeing the same drift in pitch issue and now compass drift.
Only occurs when arming the motor the first time, even after a preflight cal.
After disarm we perform another preflight cal, everything settles and when we rearm the motors everything works as it should.
I just want to report a small issue I found yesterday.
My settings are: AHRS_GPS_MINSATS = 6, AHRS_EKF_USE = 1
After my GPS had a valid 3D lock (and received 4 sats) I started in "Stabilize" and switched to "Position hold" shortly after.
While still in "Position hold" the only stick input I gave was some yaw. Suddendly I noticed a small jump upwards (~1,5m), this happend only once.
In the log I found following:
Number of satellites increases to 6 at 16:27:02
AHR2 values start at                         16:27:12
The jump happens at                         16:27:22
So I assume it has something to do when the EKF kicks in or similar.
For sure it's easy to avoid (just wait for the appropriate number of satellites before launch), but maybe somebody wants to improve that.
Best regards,
lakeroe
William,
    Yes, I tink MarkM is right especially if you're arming from the mission planner.
Lakeroe,
Yes, it's a known issue when using the EKF.  It takes a little while to warm up and the switch from DCM/InertialNav -> EKF leads to a little jump.  It's on the issues list for AC3.3 although for AC3.3 we will be dumping InertialNav completely I think.  That may force everyone to wait a little longer before take-off than they current do .. or maybe we can speed it up the settle time for the EKF.  We shall see!
Micha,
What size of propellers are you using?i'm curious about your pids concerning to loiter,if you could share it would be helpful. Ours is a 5.5 AUW with no payload,2880 props,apm 2.6 and 3dr gps,6S battery.
Rate loiter P=1.25
Rate loiter I=0.7
Rate loiter D=0.05
Loiter PID P=0.9
It does little circles around the point,less than 1 m radius,and i think it can be improved
Thanks in advance,
Can it also do so when the sonar sees the ground, maybe set at 5 metres?
Is that the "INAVERR" AC3.2 is reporting (nearly the whole flight log); the so called "speed error" as some refer to it, and which you said may be a red herring?
I'm just looking at everything possible before taking up my copter again.
Doug W noted the K index may have been a contributor to the twitching and drifting I had last weekend which fortunately only lasted seconds. Normally I check the index, but didn't that day. NSat and hdop were excellent....maybe having such a good GPS made me complacent.
DG,
I've posted a reply on your post over here but I can't immediately see the log file.  The INAVERR appearing in the PM message is different and is most likely a GPS update problem.  That's not a red herring but rather a real problem i think.
No one able to help ?
RTL is not supposed to work this way I guess
Hi Manuel,
Line 13476 "Battery failsafe"
Could this be the cause of land?
Miguel
