Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Hi Miguel,
That line 13476 you're referring to is on the first log 2015-01-27-16-29-42.log which relates to FAILSAFE_BATT indeed and caused RTL but it worked fine, RTL went to it's final altitude of 2.5 meters
However, on the second log (FAILSAFE_BATT kicked in at line 14111) and engaged RTL but the quad tried to land instead of staying at 2.5 meters altitude. This is the thing I cant understand...
Okay thanks..
You're right Manuel I was looking at the wrong log.
So it went to RTL then it changes to loiter and DAlt changes to zero only when flight mode changes also to stabilize.
Alt seems right...
I wonder if AC is getting a 3 meters high altitude reading although it is at land level...
Looking for experts reply :)
Miguel
@Manuel,
Nice analysis.  On that last part I can help.  If the failsafe is a radio failsafe (i.e. tx/rx lose contact) the RTL will land instead of stopping at the RLT_FINAL_ALT because if it stopped at 2m the pilot would have no way of commanding it to land and it would just hang there until the battery ran out.
@Randy, Hi
Didnt know that RTL worked that way, good to know :)
However, the failsafe that was triggered was FAILSAFE_BATT , so it's not a radio related problem.
So I cant quite understand why DAlt went to 0, it was like RTL was meant to reach an RTL_FINAL_ALT 0, when it wasnt set to 0.
Yes, I tried to change modes while it was landing because I dont like my copter to land all by itself on concrete, as it always likes to flip over.
So to prevent that I changed mode to Stabilize/Loiter (cant remember) but the quad was almost hitting the ground when I did that.
yesss..
Hi George Randall,
Sorry I didn't see this. I have had a look and two things look strange here. The first is that it looks like your alt hold altitude didn't reset to your current value before you took off again and also your autotune values seemed to not have an effect past a point.
I hope the new autotune will not have this problem (if that is what it is).
I am looking over the latest alt hold to see to make sure it shouldn't do what your logs suggest the old code is doing.
i'm having the same issue on 2 machines ! both pixhawk
100% reproducable in alt-hold or pos-hold, can someone explain what this Error exactly means ?
Bad variance of what values ? any idea how to solve / debug it ? my solution at the moment is to turn of EFK :-(
or if enable to switch to stabilize and fly manual.
Thomas
Without a log it's hard to tell, but if it's the EKF complaining then the heading is likely incorrect which could be a compass issue.  There's some documentation about it here.  Turning the EKF is not a terrible idea if it's not working for you.  DCM+InertialNav is the default for AC3.2.1 in any case.  The only thing is that EKF is generally better at reporting problems than DCM+Inertial nav so it could be a real issue which the vehicle's setup.
I have an APM with a bad sonar analog input 0.  I changed to analog input 2 with parameter RNGFND_PIN=2. However flight data user values sonarvoltage and sonarrange are displaying random values. Are there any other parameter changes required when relocating the sonar from one pin to another?
Hello...does anybody here have information when new generation of Lidar Lite will be avalible?
also did any of you try PWM connection ("This works around a number of bugs in the I2C interface for the Lidar. The bugs include generating spurious pulses on the I2C bus and lockups of the Lidar in flight.")?Is it possible in Ardu:Copter too,not only Ardu:Plane?
http://copter.ardupilot.com/wiki/common-optional-hardware/common-ra...
should I buy this or wait?wait for how long?
