Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
What version of AC and MP are you using?
If it wasn't flying okay in alt-hold or loiter, you shouldn't have tried any auto mission to be honest.
It will most likely be your vibration (especially z axis) issue.
Go to Advance Parameters> LOG_BITMASK and make it "default + IMU" then save.
Get your copter up in a stable hover in stabilize mode (Do NOT use alt-hold or loiter).
Fly a minute or less and land. Then post the dataflash log here so we can check the vibration level.
But make sure you fly in calm winds and you have to let the copter in hover by itself (kind of hands-off hover) to get accurate vibration reading...
3.2
1.3.17
Did you see a bad sat count prior to your change? I seem to see a decent sat and hdop just doesn't act like it. Maybe the sat data comes and goes with the interference? Anyway I will move the receiver and cross my fingers. Thanks guys
There was a discussion about the X8R interfering with GPS here
http://www.rcgroups.com/forums/showthread.php?t=2225318&page=42
Thanks. I moved the X8R it made no difference so I don't think that has anything to do with my problem.
Okay I give up. Pulling my hair out trying to figure out why my quad started toilet bowling and 'flying off' in all directions. I had it all dialed in flying nice but had a prop break in mid flight probably 20 meters up. Had a hard landing but nothing horrible. I get home and decide to upgrade to my shiny brand new taranis and X8R. I also upgraded to the last 3.2  but now I'm having problems. Should not have done so much at once now I'm not sure what the problem is. I simply cannot reliably get poshold to work well anymore it just seems twitchy and often just starts wandering off. It used to hold position within a couple meters easy. I re-did the calibration and compass calibration several times. I keep getting insane high reading on the internal compass.. I have no idea why. If somebody could look at this log and find any clues I'd really appreciate it. It is a 3Dr pixhawk. Ublox7 w/ compass. X8R receiver with Teensy.
Mmm, interesting.   I've been using the 1.3 Vtx with the APM for two years now.  But I did reduce the size of the tricopter arms which moved it closer and so that makes sense.
On the ppm issue I'll look into the settings in Opentx and the micro Rx.
Hello Alex
Thanks for taking the time to help.
To answer a few questions,
Set PID's back to default
Their is foam over the Barometer sensor
Increased  INS_MPU6K_FILTER to 10 the 20. Default 0. Noticed slight improvement
Note INS_MPU6K_FILTER set back to 0 for log
Throttle set to mid
Props balanced
Balance of copter good. Hung by string at mid point.
Still pulses in alt and loiter
Log attached Default + IMU
Hope this helps
Cheers John H
New Zealand
Logs attached ti
his time
Both compasses have high offsets. GPS modes need a good compass reading.
If you look at the GPS plot you will see your copter flew into the trees a couple of times.  I'm sure that did not happen.  I think because of the trees the GPS is getting distorted causing position drift issues.  I have already had it happen while landing near my house to have the copter come right at me very fast because the GPS suddenly drifted into my house and the copter reacts be moving in the opposite direction.
Try flying in an open area free of obstructions and see if the same thing happens.  Otherwise you need to get above the tree line and hope it doesn't fly away.
Also the GPS subsystem reported a number of glitches during your flight.  Also EKF reported issues as well.
Your right about the high MAG values and offsets.  Don't know what that is.
