Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Hello...does anybody here have information when new generation of Lidar Lite will be avalible?
also did any of you try PWM connection ("This works around a number of bugs in the I2C interface for the Lidar. The bugs include generating spurious pulses on the I2C bus and lockups of the Lidar in flight.")?Is it possible in Ardu:Copter too,not only Ardu:Plane?
http://copter.ardupilot.com/wiki/common-optional-hardware/common-ra...
should I buy this or wait?wait for how long?
Emin,
I think the PWM interface won't be supported in ArduCopter until AC3.3 (beta testing should start soon-ish though).  On the dev team we've heard good mumurs about the Lidar-Lite guys resolving the I2C issues but we haven't yet gotten any samples to test yet.  I think all the Lidar-Lite sensors being sold by whatever retailer (Sparkfun, etc) have the I2C issues.  Personally I would wait until we confirm the I2C issues are resolved.
THX
If using sonar for altitude how does the upcoming 3.3 code deal with the baro sensor? Is it going to be just one or the other or is the baro going to take over after X amount of altitude?
What's the different between sonar and optical flow? Can the pixhawk use both? I'm very interested in how the optical flow could work for landing on a moving target in my case a boat. If the optical flow see's the boat and the boat drifts away a bit it could compensate. That would be really cool!
Also really interested in how sonar would work over water. I emailed Lidar about this and did not get a concrete answer but it was suggested it's likely to work okay if it's not too high.
Hi all, did you successfully solve it? Tomas
Hello, guys! I'm from Brazil, computer science student and my english is not very good, so, please, I'm sorry by my possible errors in write. I have a question about the sonars which can be use in APM 2.6. I'm beginner in world of APM, but I would like know if can I use the sonar Maxbotix LV-EZ1 in the APM? My objetive is implement one algoritm simple for detect obstacles in your front and divert or lock your position (I'm still thinking about). I need use the sonar EZ1, because here, in Brazil, is more cheaper than others models Maxbotix.
I decided make this procedure like part of the my monograph, because I think it will stay cool. Thanks by the contributions of all.
Thanks for the suggestions, Richard Kennedy.
I too am having exactly the same problem. The radios are 20 cms apart and the "Timeout on read - Get Log" error message pops up and signal drops straight to < 20% ( random ) and continues to go down and then takes a good 2-3 minutes to ramp up to 95%-98% - Never 100%.
I have also noticed very frequent drops i.e. No Data received whilst quad is in air and within 30-40 meters of GCS telemetry module.
I have tried 3DR ( SiK v1.9 ) radios as well as RCTimer ( SiK v1.7) ones - same problem. So it is not a radio hardware or antenna problem.
Running AC 3.2.1 and MP 1.3.34
Does anyone have any clue?
Disabled ECC check and downloading log works and no timeouts. But the radio range is still a problem.
currently I am still using 3.1.5 but would like to change to 3.2 because of some features in mission planning i.e. Do_Change_Speed command.
Question is: Is 3.2 stable to fly? What I see is that the developers are already at version 3.3 beta testing. From my understanding that means 3.2 is free of fatal errors just some minor features need improvement in the next version.
I am on an APM so 3.2.x is the highest version I can go but I need a safe and stable to fly firmware without fancy features that cause problems.
Grateful for any help
Cheers
Axel
