I plan on using the Arducopter (kit) with a bucket load of Radio signals, RC -- telemetry -- POV -- Pan Tilt control. I’m hoping that someone here may have recommendations for frequency's, and manufactures.
I’m thinking:
2.4GHz RC radio system for the flight controls (no idea what brand to go with.) looks like 7 channels are recommended.
2.4GHz for the wireless POV (already have this item, but willing to trade out.)
900MHz for the telemetry (60mW Xbee with wire antenna) also looking for recommendations for antenna type.
72MHz for the pan tilt (Hitec Neon SS 3channel system)
hi jani , long time .. i have accomplish lot of work .. i am working on many projects.. i want you to tell me if you had any problem with switching modes with analogic radios before?
Hi Cybercrash
I too have a 9x TxRx.
Which re-flash version would you recommend.
Does this firmware enable you to map any of the switches (TRN, THR CUT etc) to any of the channels?
This would be a great advantage as I would prefer certain switches for certain functions.
I tried to find something to read about whether this was possible but have not found anything yet.
JohnL
John, i'm currently working with turginy radios and testing different firmwares for ArduCopter use. I should have some reports about those in week or so. Er9x is one most promicing but even that have some problems with center stick areas and scaling whole stick movement so we need to do patching to it.
Hi Jani
Thanks for the reply - I'll be keen to see the results of your firmware tests.
I'm still looking into the best way to program the 9x at the moment, the hardware mod or the plugin mod which I think will not be available until next month.
Again thanks
Hey Jani, you legend,
can you point in the right direction on how to set up the Camera pan-tilt system with the Arducopter?
I've got the Turnigy 9x as recommended, as waiting for HK to get Pan-tilts back in stock....again!
thanks very much!
Owen
Some advice:
1. Get the FlySky/Turnigy Th9x  v.2  mode:2
2. Get the Robby Roxxy 2827-34 with apc 10x4,7   (I use them and they are great, but there are other motors as well:
3. Get a cheap cam for your copter: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
4. With a video transmitter/receiver (5,8Ghz): http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
5. And of course video goggles: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
This is the cheapest video equipment there is. I am using this set for over a year now and it is really, really great. The video goggles are on backorder so I have to wait to get them. I flew with 7" video display until now.
CyberCrash
Good advice Cyber, I'll pick my way through that shopping list at some stage. I really want the fpv for pan tilt control in unison with my GoPro HD, so I know i'm pointing in the right direction for photo/video capture. Do you use the pan-tilt too, and if so, do you have the instructions on how to link it up hardware wise, and code alterations Arduino wise?
cheers! Owen
Hey Owen,
I am sorry, I didn't built a pan-tilt option, yet. I am still waiting for the release of the ArduMega software.
If I am not mistaken the GoPro HD does offer a video out signal you would be able to send to your goggles so that you could observe the picture you are recording.
Best regards
Kai
Thanks for the reply Kai, I never even considered that, I'll look into that option. thanks very much!
Hi All,
How about Futaba 8FG Super?? thx
AK
