Hi guys, so I was hoping to use the arduIMU as sort of like an arduino with an accelerometer attached. I'm using "ArduIMU V3 1.9.8 (Edwin and Michel Edition)" through arduino v1.0.1 and I think I got everything to upload properly but I had a few questions.
Firstly is it okay if for now I power the board through my FTDI board?
Also can I run the whole board through 3.7v battery and 3.3v board? As from looking at the schematic sheet I'm thinking that the only parts I need should be able to run off this voltage?
Also I noticed a whole heap of people were able to show accelerometer data through their serial monitor, but when I open mine up with my FTDI board it just shows a lot of maligned writing through all my different baud rates?
If it helps whenever I power on the board the Z and Y LED flashes like crazy for a lil while and then I get the maligned data appearing on the serial monitor and the LED stops flashing
The crazy looking characters are probably binary if changing baud doesn't fix it. Check your #defines in the sketch and make sure #define output binary is set to 0. If you have ArduIMU_Test, you can see the data coming through in a window and you get a nice display that's better than the serial monitor in arduino and it will work with ascii or binary. If you connect to an old ardupilot you'll need to output binary.
bump?
