ArduPilot Throttle Channel
Hello All,Getting a setup going. Everything appears to be working well, except the throttle.Obviously, going straight into the Rx works just fine.The ESC normally plays a startup tone, and then 3 beeps to let me know it's ready. It does this when going straight into the Rx.If I jump the Rx into the "in" side of ardupilot.And hook the ESC into channel 3 on "out" side.I get the startup tone, but not the following three beeps.Has anyone else experienced something like this?I've quadruple checked the servo connections, and they're correct.Any suggestions?Thank you!John C.
  • hello people, i think i have a problem with the mux (ch3 and ch4), i have been searching and reading the webpage from top to bottom and i can´t make it work...
    look at this:
    GPS... OK
    IMU... OK
    INPUTS:
    AIRSPEED...OK
    CH1.............OK
    CH2.............OK
    CH3.............OK
    CH4.............OK
    OUTPUTS
    CH1.........OK
    CH2.........OK
    CH3..........BAD TRYED CHANGING TO MUX4 not working
    CH4..........BAD
    TELEMETRY.........OK
    CGS.....................OK
    any ideas?
    seems like i am going to try and fly without throttle and without rudder also (seems like ardupilot does not support using ailerons and vtail at the same time.....
    can you please give me some ideas on what else to try..... waited long time for my ardupilot to arrive... :-(
  • I don't think this is an isolated issue as I had exactly the same problem with mux 3 and only found out recently when I started using throttle. Thanks to this post I also fixed it using mux 4.
  • John, It's possibe the mux chip could have been damaged be ESD. All is not lost. You could use chn. 4 by moving the wire from mux 3 to mux 4 and solder on the extra connectors. The Aurdupiolot doesn't read inputs 3 & 4, it's not wired. These channel's outputs are just switched from computer to receiver when going to man. mode. If it works, that would confirm the problem plus get you going right away.
    Check the continuity between the pins and these two pins on the mux.
    I assume you soldered the jumper wire so channel 3 is enabled?
    Sounds like you need to adjust the minimum throttle servo value in the header file to a lower value. I am not familiar with the Plush, but most speed controllers will not arm unless they see a low enough throttle signal (i.e. stick all the way down). If you want to test this idea hook the esc up to the rx and start it up at say 1/4 stick. If you get the same behaviour then this is what is happening and what you need to adjust. Just be careful in case the Plush does not have this feature in which case your prop will spin!
  • Admin
    John,
    I believe that the ESC is looking for a throttle control signal which it gets from the Rx at power up.
    What position do you have your Ardupilot CNTL signal at when powering up? It should be in manual. Looks like the throttle control signal is not being passed through the Ardupilot mux from the Rx when in manual.
    Just a thought.
    TCIII
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Tuesday
Monday
DIY Robocars via Twitter
Monday
Friday
Friday
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
An interesting line-following simulator to use with with your robocars: https://github.com/ron-grant/LFS
Dec 23, 2020
Dec 23, 2020
