Hello All,
Getting a setup going. Everything appears to be working well, except the throttle.
Obviously, going straight into the Rx works just fine.
The ESC normally plays a startup tone, and then 3 beeps to let me know it's ready. It does this when going straight into the Rx.
If I jump the Rx into the "in" side of ardupilot.
And hook the ESC into channel 3 on "out" side.
I get the startup tone, but not the following three beeps.
Has anyone else experienced something like this?
I've quadruple checked the servo connections, and they're correct.
Any suggestions?
Thank you!
John C.
hello people, i think i have a problem with the mux (ch3 and ch4), i have been searching and reading the webpage from top to bottom and i can´t make it work...
look at this:
GPS... OK
IMU... OK
INPUTS:
AIRSPEED...OK
CH1.............OK
CH2.............OK
CH3.............OK
CH4.............OK
OUTPUTS
CH1.........OK
CH2.........OK
CH3..........BAD TRYED CHANGING TO MUX4 not working
CH4..........BAD
TELEMETRY.........OK
CGS.....................OK
any ideas?
seems like i am going to try and fly without throttle and without rudder also (seems like ardupilot does not support using ailerons and vtail at the same time.....
can you please give me some ideas on what else to try..... waited long time for my ardupilot to arrive... :-(
