ARMING/DISARMING pixhawk using arduino uno via MAVLINK COMMS protocol
Hi everyone,
I've been trying to arm my pixhawk using an arduino uno, I took the example code from
https://groups.google.com/forum/#!topic/qgroundcontrol/K_8FIQVGqaU
to send a heart beat packet.
I also have been reading this post  - http://diydrones.com/forum/topics/overriding-remote-control-from-a-...
From what I gathered I need to use the COMMAND_LONG message to arm my pixhawk.
so I wrote this code..The idea behind the code is than when I press the capacitive sensor  it will arm then when i don't it will dis arm..... but when I did it it did not work.
please see attached for the .ino code
Would it be possible if anyone could help me on this please?? :))))))
Hi, I just figured it out after a couple of hours lol.
please find attached for the arduino code.
hi there,
I realise this is 3 years late but I was using your code to work on the same project as yours. To interface pixhawk and arduino uno and programme it to arm/disarm and to make it autonomous at one point.
I put your code into arduino IDE and am getting the following error.
"fatal error: AP_HAL/AP_HAL.h: No such file or directory"
Even though i have this AP_HAL in my library folder.
I was hoping you or anyone would be able to walk me through this.
I use this library now - https://github.com/mavlink/c_library_v2
clone this to your library folder on i.e. "Documents/Arduino/libraries"
and I include it like this on my sketch
#include <c_library_v2/common/mavlink.h>
Jamie Tank said:
hi there,
I have done this and yet it still comes up with an error now saying
"fatal error: c_library_v2/common/mavlink.h: No such file or directory"
I am confused to why it still isn't compiling when the path on the code and the library is correct.
Jamie Tank said:
hi there,
That I dont know how to solve. lol.
I am using visual studio 2017 with visual micro plugin
VS - https://www.visualstudio.com/downloads/
visual micro - http://www.visualmicro.com/
once you can compile a arduino project i.e. a blink code on this then enable "deep search" under vMicro tab>> compiler>>deep search
That works for me. let me know how it goes.
Jamie Tank said:
hi there,
Recent (sort of) Arduino IDE updates changed the way you can reference libraries in subdirectories. This SO post should hopefully help you figure it out: https://stackoverflow.com/a/43819733/1940286
