Edit: Success - http://diydrones.com/profiles/blogs/it-works-fully-automated-parach...
I want to try this with my quad and see if and how it works.
Here's my waypoint list:
Basically takeoff to 6m (will actually take off the ground myself as AC v2.7.1 doesn't seem do the takeoff).
Then fly to a close waypoint at 10m alt, then to a further waypoint at 60m alt, loiter for 5 secs, release the chute, loiter for 5 secs, descend to an interim waypoint at 30m, descend further to a closer waypoint at 15m and RTL from there. This is in a fairly open area and the drop will be about 60-70m from the takeoff. May change the waypoint positions if there's a bit of wind.
Does that order & logic look about right?
Tags:
apm 2.5 and arduplane 2.68version ,I have replaced ap_camera files from here trigger function perfect by manual in MP,but still not work on waypoint , i think the camera code not complete at present , I really would like to know when will release next arduplane version.
thanks a lot.
Tang
All the fixes have been done apparently in ArduCopter v2.9 but it's still in release candidate stage, so not sure if someone has tested it yet. I'm trying to repair my APM2 so am out of action for a bit.
Getting closer to having this working (with ACv2.9). The release servo works on the ground with CH7, but am using the DO_DIGICAM option for the mission.
Will test hopefully in the morning...
I would like to do servo in WP but i don't have method to do it
Any Luck?
Has there been an update to this - I am trying to get camera trigger to work using a transistor and it is not clear how to set this up in the mission planner. There are some transistor options on channel 7 and on the shutter section of camera hardware options, but neither seem to cause anything to happen on the output (i have only checked RC 8). Randy mentioned hardcoding it to PIN 9, is that what was done?
45 members
1472 members
282 members
470 members
57 members
Powered by
